976227 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 15, 2026, 08:20 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  removing crank arms
Author Topic: removing crank arms  (Read 3233 times)
2020mad
removing crank arms
« on: December 24, 2005, 07:52 PM »
any one got any tips how to remove a set of profile crank arms without damaging arms or bike they are stuck on had soaking in wd40 all day and still cant get them off. cheers
Offline Rombloke
  • do one
Re: removing crank arms
« Reply #1 on: December 24, 2005, 09:56 PM »
profile removal tool.....7 quid
easy
Dave
haro, how do you do
« Reply #2 on: December 24, 2005, 10:35 PM »
You may end up sacrificing the bolts,  but you can wind them out a turn or two, steady the frame and then beat the crap out of them.  Something will move..... ;)   Check to see if the gap has changed, wind the bolt out another turn or two and continue.  Noisy, but effective  :)
TOMMY2WHEEL
« Reply #3 on: December 29, 2005, 03:09 AM »
Crank puller or removal tool are the best to use. they seperate the arm from the shaft evenly with minimal ware to the splines or wedges. use what the crank manufacture suggest.
weston
« Reply #4 on: December 29, 2005, 09:19 AM »
there was no way of getting the one from my old bike. i had to saw through the spindle to get it off..
greentoad
« Reply #5 on: December 29, 2005, 12:10 PM »
Hi  :santa_wink:
If you do get stuck it might be worth visiting a local garage (if you know one) and using a puller, or buy one. They are quite handy.
http://buy1.snapon.com/catalog/catalog1.asp'tool=all&Cat_ID=124110&Cat_NAME=Pullers&store=uk
Example the 2 or 3 Jaw Pressure Screw -
http://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=9952&group_ID=1171&store=uk&dir=catalog
It is most important to give the item a good soak, and then start to undo very slowly then tighten a little, spray then undo, tighten etc...
I also did a post a while back, and the Freeze Spray is very effective and is used on Large / Heavy Machinery down to small bolts etc when out in the field. That really is a must thing to have.
Hope this helps
greentoad
wirewheel
« Reply #6 on: January 11, 2006, 01:17 AM »
like the man says, usa the right tool, a profile tool no other way without fooking something up.
Offline diesel
« Reply #7 on: January 11, 2006, 08:53 AM »
Here's what I use... Its very effective!
I use a medium size socket set extension bar that fits neatly into the end of the crank arm and dosent touch the sides. I then lay  the bike down onto some wood covered with towels. and give it a couple of hits with a hammer. If its really stuck in there proper, you maybe want to stand the bike up rather than lay it down. Put the towels round your legs instead and brace the bike against them.
It pops out nice and easily!
Offline ORB
« Reply #8 on: January 11, 2006, 10:51 AM »
hammer is the best method of fixing anything, even a slow puncture.
12
2020mad
« Reply #9 on: January 11, 2006, 02:21 PM »
They wanted £16 at my local bike shop for removal tool so going to try diesels method tonight.
« Reply #10 on: January 11, 2006, 08:51 PM »
Just be a little bit careful bashing a socket with a hammer...  If its a chemical black impact socket with thick sidewalls, then whack away  ;)  but if its your regular chrome cheapy, they have been known to shatter.... Not often but I have seen in happen.   :)
Offline ORB
« Reply #11 on: January 11, 2006, 09:13 PM »
my mate has a glass eye from smacking a crankshaft with a hammer.
12
« Reply #12 on: January 11, 2006, 09:27 PM »
..........is exactly what I'm on about...... a little caution there chap   :daumenhoch:
Sanmarcopizza
« Reply #13 on: January 12, 2006, 09:07 AM »
And I bet you bore it to sleep.
« Reply #14 on: January 12, 2006, 10:20 AM »
lmao!!!!!
Offline jT Racing
  • i like bikes. :/
« Reply #15 on: January 12, 2006, 10:56 AM »
piece of bar or socket just amller than the opening, big hammer, tap tap tapppy tap whack.
ding dong
