976297 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 21, 2026, 06:38 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Chainring Problem.
Author Topic: Chainring Problem.  (Read 1614 times)
ligbee
Chainring Problem.
« on: April 14, 2008, 08:22 PM »
Bought a couple of chainrings (Sugino/SR style) to which I was going to fit a standard Spider. When I tried to bolt the spider onto either of them, it seems that the spider is too small, is there two sizes of spider or is it a power disk fitting only.
Don't remember this problem back in the day.
ligbee.
crusty
Re: Chainring Problem.
« Reply #1 on: April 14, 2008, 08:32 PM »
how much to small/big?
are you putting all 5 of the bolts in loose before you tighten any up there are a lot more knowledgable people on here that can help but this is all i can think of for now
ligbee
« Reply #2 on: April 14, 2008, 08:34 PM »
You cannot as the pcd of the spider is too small, the radius of the holes could do with being about another 10 mm.
ligbee.
« Reply #3 on: April 14, 2008, 08:35 PM »
i could be wrong but it sounds like you've got a Sugino spider and Takagi chainring?  the Sugino spiders are smaller, thus there rings are bigger and the oposite for Takagi.
hope that makes sense?
ligbee
« Reply #4 on: April 14, 2008, 08:37 PM »
That sounds about right.
I'll have to find out which one is which as both chainrings and spiders are copies.
ligbee
« Reply #5 on: April 14, 2008, 08:39 PM »
yeah i did exactly the same mate, i had a sugino spider and then bought a Takagi chainring, you need a Sugino chainring mate  :daumenhoch:
ligbee
« Reply #6 on: April 14, 2008, 08:40 PM »
Cheers for that.
Thats why this site rules.
ligbee.
mark 2
« Reply #7 on: April 14, 2008, 08:43 PM »
Well it sounds as if you got a 130mm bolt circle diameter chainring, something like a takagi, shimano or tioga (same thing) and a Sugino pattern spider which has a bcd of 110mm. You'll need either a Sugino, Suntour or Tuf Neck chainring to fit or get a powderdisc with the dual holes
Here's a 130mm
And these are 110mm
Hope that helps :daumenhoch:
***pickle answered while I was typing so it looks like I 've just copied him :LolLolLolLol:
« Last Edit: April 14, 2008, 08:45 PM by mark j. »
crusty
« Reply #8 on: April 14, 2008, 08:44 PM »
i told you there be some smart people on 'ere
ligbee
« Reply #9 on: April 14, 2008, 08:47 PM »
And just a click away as well.
Proper threw me out as I've never come across this before, just been lucky I suppose.
ligbee.
mark 2
« Reply #10 on: April 14, 2008, 08:48 PM »
Too much time on their hands more like :LolLolLolLol:
