976298 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 22, 2026, 02:04 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Removing Oakley B1B Sleeves ???
Author Topic: Removing Oakley B1B Sleeves ???  (Read 1963 times)
Offline brass monkey!
« on: April 16, 2008, 12:57 PM »
Chaps !!
I need some advise on removing B1B Sleeves, the grips are NOS so I'm reluctant to stick screwdriver inside to loosen em, does anyone have a tried n tested method?
Also I need to fit new ones (different colour) - the Oakley box says soak the sleeves in Paint Thinner ??? is this the best way to get them on ?
thanks
Matt
othomas2
Re: Removing Oakley B1B Sleeves ???
« Reply #1 on: April 16, 2008, 01:05 PM »
With some oakley copies I soaked them in hot water and literally pealed them away inside out... that was after trying to be more careful and not getting very far. The stretch overall should be sufficiant enough not to rip them... I wouldn't just stick with my advice though...
If you carefull can be a right pain... you can put the sleeve on by sliding it on in between the holes.
« Reply #2 on: April 17, 2008, 11:43 AM »
 airline from a compressor
with a blower on it rom bloke does it
« Reply #3 on: April 17, 2008, 03:01 PM »
Its funny I was going to ask this same question, I read about the thinners but didn't think this would be a good idea.
I did think about using GT85 or WD40
Rhys I don't understand what you mean  :-\
« Reply #4 on: April 17, 2008, 03:23 PM »
Matt ,
Check out this ............................
http://www.os-bmx.com/forums/index.php'showtopic=30490
Maybe that helps .
« Reply #5 on: April 17, 2008, 05:37 PM »
an air blower they use in bodyshops and mechanics
to clear dust and stuff
just aim at grips and presto they blow off lol
ask dave he does it
« Reply #6 on: April 17, 2008, 05:39 PM »
This is to remove the sleeve off the grip though  :-\
« Reply #7 on: April 17, 2008, 05:42 PM »
oh the sleeve not the whole grip
feck knows then lol
Offline JAY
« Reply #8 on: April 26, 2008, 04:55 PM »
Just dip them in some soapy water,and work them off. pease of piss ..........Just don't get angry and kill them ;D
mark 2
« Reply #9 on: April 26, 2008, 07:03 PM »
You've obviously never peeled a condom off a warty sausage Matt.....good boy ;)
Offline Waxintaxin
« Reply #10 on: April 27, 2008, 02:48 PM »
roll em off , bit of warm soapy
to put new ones on used wd40 and they just slide on easy
just did some
Rich
« Reply #11 on: April 29, 2008, 09:31 AM »
just seen these replies,
thanks you luvely lads !!  ;)
LOL at markj's reply !!
