976298 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 22, 2026, 03:40 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  brake help., trev???
Author Topic: brake help., trev???  (Read 3245 times)
jedi
« on: April 28, 2008, 11:42 PM »
i remmeber someone saying trev is good for brake advice.
anyway, i have an evo2 caliper ,mtb sticky pads,linear cable and push lever on a chrome rim but i dont lock up the rim.
also if i get a front brake whats the best to get and set up tips?
Trev
Re: brake help., trev???
« Reply #1 on: April 29, 2008, 12:12 AM »
brake help from me?? hahahaha... i am the original brakeless rider who rides with two brakes. i've never got any brakes to work properly.
however, if you need a good front brake then a Suelo is a good choice.
darkersomeday
« Reply #2 on: April 29, 2008, 12:19 AM »
are you 100% definite that the push lever is u-brake specific?
if its a v-type lever it'll be pulling too much cable and wont give the leverage needed to lock up the rear wheel,
its the only thing i can offer as the rest should work spot on,
what pads are they? many mtb pad makers swear that their pads are sticky but in reality are just regular pads,
heatsink are definitely sticky! kool-stop pads are good too, tried and tested,
not being funny but is the rim clean? i mean "squeeky" clean?
is the brake chain or seat stay mounted? is there enough pull angle on the caliper?
jedi
« Reply #3 on: April 29, 2008, 08:27 AM »
the lever is off a mongoose expert.i like the feel of the lever.
the rims clean and the brake mounts seat stay.
heatsink pads you say?who makes them/imports them?
« Reply #4 on: April 29, 2008, 08:31 AM »
also try taking the pads off and giving the faces a good rub with sand paper, they often get a glazing over them and this makes them slip.
jedi
« Reply #5 on: April 29, 2008, 08:34 AM »
i'm off to corby today so i'll pop into marshalls cycles 1st to let them do it   :laugh: :daumenhoch:
« Reply #6 on: April 29, 2008, 09:12 AM »
You may like the feel of the lever but as DSD says if it's a v-brake lever it won't work with a u-brake as it pulls too much cable, that's a compatibility issue  :D
Get them to check/verify the brake lever as above  :daumenhoch:
jedi
« Reply #7 on: April 29, 2008, 09:15 AM »
its off a u braked mongoose
« Reply #8 on: April 29, 2008, 09:17 AM »
Cool, might just need some fettling of the cable and some better pads like Koolstops  :daumenhoch:
« Reply #9 on: April 29, 2008, 09:18 AM »
you'll get a bike shop to do it??
SHAME ON YOU SIR!!!   :shocked:
jedi
« Reply #10 on: April 29, 2008, 09:19 AM »
been looked after/sponsered by them for years (road/mtb)
jedi
« Reply #11 on: May 02, 2008, 10:07 AM »
who imports heatsink pads??
« Reply #12 on: May 02, 2008, 10:25 AM »
Oil the cable, deglaze the pads or try new ones. Also, you want the minimum amount of spring tension on the caliper you can get away with. Just enough to twang it off the rim, and no more.  When you have the pads off to deglaze them, spend a little time postioning them nicely when they go back on   :)
jedi
« Reply #13 on: May 02, 2008, 07:00 PM »
anyone used simple green on their rims??
darkersomeday
« Reply #14 on: May 02, 2008, 07:46 PM »
if it were me i'd try another lever, just to see if the problem is there,
you shouldnt really need something as severe as simple green for the brake to lock,
http://www.heatsinkbikes.com/index.php?p=brakepads
be warned though, theres no modulation with these puppies! they come on like a stick-in-the-wheel! :daumenhoch:
jedi
« Reply #15 on: May 02, 2008, 07:50 PM »
i got a tech 77 coming to try out
Voodoocars
« Reply #16 on: May 02, 2008, 07:56 PM »
Try some ACOR transparent pads.Squeal like a stuck pig but stop on a dime.
jedi
« Reply #17 on: May 02, 2008, 08:04 PM »
im not bothered by squeel. good tip ian,cheers
