976298 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 22, 2026, 03:16 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Redline Proline Help (Again)
Author Topic: Redline Proline Help (Again)  (Read 2274 times)
Offline Brandy Truffle
« on: May 01, 2008, 01:34 PM »
Still on the hunt for an early Proline F+F... Have i found a frame here?
Can someone confirm if this is definately a PL frame? It looks like it has 2 diff era decals on,but the headtube looks 5"?  :-\
Frosty
Re: Redline Proline Help (Again)
« Reply #1 on: May 01, 2008, 01:42 PM »
what is that on the drop outs??
It looks ok to me apart from the drops and also the bottom of the head tube can't really see clear enough if it is flaired or not like mine
« Reply #2 on: May 01, 2008, 02:08 PM »
Like Paul said , not sure what's going on with the dropouts  :-\ .
The seat tube decal would work with a frame with no support to the rear of the BB ( downtube is later decal ) .
And a close up of the headtube needed  ;) .
« Reply #3 on: May 01, 2008, 04:50 PM »
I'm wondering if it's a mount for those eliptical chain tensioners  :-\
« Reply #4 on: May 01, 2008, 05:28 PM »
I'm thinking that too , early chain tugs/tensioners  ;) ( kinda mid schooly thing ) .
« Reply #5 on: May 01, 2008, 05:32 PM »
So what, someone drilled frame aftermarket mod etc?  ???
« Reply #6 on: May 01, 2008, 05:41 PM »
Err yes, maybe  :-\
« Reply #7 on: May 01, 2008, 05:43 PM »
Dont buy it without forks, the forks are rarer than the frames now. I hunted high and low for replacement forks.
The frames are pretty much bomb proof but the forks crack on the drop out fairly easily.
If the pic is a PL frame then its an early unbraced one, so the stickers are probably not correct :daumenhoch:
« Reply #8 on: May 01, 2008, 05:45 PM »
Seat tube sticker is correct  ;)
« Reply #9 on: May 01, 2008, 05:57 PM »
A yes oh Redline Master.... which does mean the down tube one is wrong :daumenhoch:
