976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 22, 2026, 11:46 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  shim for 1 1/8 stem to fit 1" threadless forks
Author Topic: shim for 1 1/8 stem to fit 1" threadless forks  (Read 1789 times)
firebird4130
« on: May 19, 2008, 06:22 PM »
Hi, can anyone tell me if I can buy a shim for this or if there's like an easy way to do it yourself,
Re: shim for 1 1/8 stem to fit 1" threadless forks
« Reply #1 on: May 19, 2008, 06:36 PM »
i made mine mate out of a pair of khe grip rings in alloy
just took both down a nano and they fitted perfect
i cut a slot in the side of both to let the thing grip when it was tightened
tobybrown35
« Reply #2 on: May 19, 2008, 06:39 PM »
     crupi make one 2 bout 7 dollars :daumenhoch:
firebird4130
« Reply #3 on: May 19, 2008, 07:12 PM »
cool, where can you get the khe rings from or the crupi one ?
motomagII
« Reply #5 on: May 19, 2008, 07:25 PM »
billys bmx shop also have these give em ring though dont think there listed on their web site
firebird4130
« Reply #6 on: May 19, 2008, 07:49 PM »
thanks for the info, sorted  :daumenhoch:
« Reply #8 on: May 21, 2008, 10:33 PM »
Akira is  not called Simone
whereas you on the other hand  are ::)
and you have been seen at a gym in Birkenhead
doing bench presses  in a back to front thong for Purple aki
Court ajourned  :-X
