976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 07:51 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Pedal stuck to crank arm.
Author Topic: Pedal stuck to crank arm.  (Read 2169 times)
BmxBandito
« on: May 28, 2008, 11:21 AM »
Stripping down this bike for repainting when i get to the single piece crank, i take the pedal off the chainring side, and procede to the other side will it move, you bet your ass it won't, any suggestions, techniques???
Goose1
Re: Pedal stuck to crank arm.
« Reply #1 on: May 28, 2008, 11:23 AM »
it's left handed thread.......................you turn it the opposite way.
« Reply #2 on: May 28, 2008, 11:32 AM »
remove the crank from the frame.
put it in a vice.
spray with plusgas
leave overnight
spray again
leave again
good quality spanner, no cheap shit, scaffold tube over the spanner shaft, bobs your uncle.
alternatively, get another crank. I have a mk1 burner crank with a red chainwheel in the shed if you need it.
Goose1
« Reply #3 on: May 28, 2008, 11:35 AM »
can the crank be removed with non drive side pedal still attached?
« Reply #4 on: May 28, 2008, 11:35 AM »
Ah, you cant remove it cos its the chainring side.
hmmmm...
Id fasten it all back up use the plusgas again, and try to lock the crankarm to the chainstays with levers, straps etc, so it deosnt move when you apply force to the pedal, and yes, remember to spin it the right way.
personally id have the angle grinder through it and get another crank.
BmxBandito
« Reply #5 on: May 28, 2008, 11:37 AM »
Thats the problems the crank can't be removed so the frame is in the way and you can't get any leverage on the pedal
Help!!!!!!!
« Reply #6 on: May 28, 2008, 11:38 AM »
Help!!!!!!!
you can if you strap the crank arm to the frame.
I tell you, youve gotta be prepared to do a bit of groundwork with pedals, or they will never come off.
JT71
« Reply #7 on: May 28, 2008, 11:45 AM »
as the first reply, are you turning it the right way.
if it's the none drive side as you look at it from the side it undoes in the direction you'd expect it to do up., ie, the pedalling action would tighten it. this is why you don't need your pedals to be done up mega tight.
Voodoocars
« Reply #8 on: May 28, 2008, 08:12 PM »
I had very similar problem a while back.Dont want to rain on your parade but I tried release agent,diesel,brute force with cheap spanners,brute force with quality spanners and lots of heat with quality spanners. >:(  Nothing would make the pedal budge so I sold the chuffin' lot on ripoffbay.Its not a Ruption frame by any chance is it? :-[
BmxBandito
« Reply #9 on: May 30, 2008, 01:33 PM »
Nah it was a burner mk 1 mate, and the problem is now resolved
 :angel: :angel: :angel: :angel: :angel: praise jesus
Offline Bigfrawg
« Reply #10 on: May 30, 2008, 02:40 PM »
did jesus come round and sort it out for you then?  he can be a handy chap to have around!
my washing machine is making a bit of a noise, is he any good on hotpoints?
BmxBandito
« Reply #11 on: May 31, 2008, 03:37 PM »
nah mate he was a carpenter, not a mechanic  :LolLolLolLol:
