976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 10:19 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Skyway Tuff 2 issues...........
Author Topic: Skyway Tuff 2 issues...........  (Read 2711 times)
MINI_BURNER
« on: June 06, 2008, 09:02 PM »
I recently bought some Tuffs for my Robinson Pro but when I tried fitting the front wheel there was too much gap between the hub and forks?  Any ideas, do I just pack it with washers?
Scotty :bondage: :(
djgivvinup
Re: Skyway Tuff 2 issues...........
« Reply #1 on: June 06, 2008, 09:45 PM »
how much of a gap are you talking?  any pics?...:daumenhoch:
« Reply #2 on: June 07, 2008, 05:59 AM »
Yep, you can pack it out with washers or just leave it but that then puts the forks under a fair bit of stress.  My TX1200 forks need about four washers a side to pack them out  :daumenhoch:.
MINI_BURNER
« Reply #3 on: June 07, 2008, 09:18 AM »
I'm guessing there is 5 to 8mm either side, washers it is then :daumenhoch:
djgivvinup
« Reply #4 on: June 07, 2008, 09:39 AM »
I would try & find some spacers or fat washers, i would have thought the less washers filling the gap the better? just my opinion  :daumenhoch:
« Reply #5 on: June 07, 2008, 11:00 AM »
Interesting, why do you think that?  Once the wheel is tightened they won't be moving about so long as they are the right size.
« Reply #6 on: June 07, 2008, 01:04 PM »
i used some thinner cone lock nuts
MINI_BURNER
« Reply #7 on: June 07, 2008, 01:12 PM »
I just robbed a pair of the hub nut thingys of another set of wheels, they are the same thickness but the wheel sits off centre!?  I'm tempted to take them off and just tighten the forks up!!
djgivvinup
« Reply #8 on: June 07, 2008, 08:23 PM »
to be honest i don't know  :LolLolLolLol:  just seems logical, if you can have one thick washer each side to fill the whole gaps wouldn't that be better than three or four each side that you'd have to get in place when you fit the wheel?
Or i could just be completely mental  :idiot2:  :LolLolLolLol:
« Reply #9 on: June 08, 2008, 08:54 AM »
Well it is mandatory to be a member of this site  :LolLolLolLol:
« Reply #10 on: June 08, 2008, 09:26 AM »
just tighten em up
« Reply #11 on: June 08, 2008, 09:30 AM »
2020mad
« Reply #12 on: June 08, 2008, 09:33 AM »
or give them to me and use spokes  :LolLolLolLol:
« Reply #13 on: June 08, 2008, 09:33 AM »
yes
