976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 19, 2026, 05:45 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Making pads
Author Topic: Making pads  (Read 2746 times)
Jazzchimp
Making pads
« on: January 06, 2006, 01:57 PM »
Anyone got suppliers of the material and foam they would like to share with me for a price?? ;) ;) ;)
Re: Making pads
« Reply #1 on: January 06, 2006, 01:58 PM »
this has been done before, and im sure there was an answer.
Re: Making pads
« Reply #2 on: January 06, 2006, 01:58 PM »
not that i know it like
Re: Making pads
« Reply #3 on: January 06, 2006, 02:03 PM »
well pipe lagging will do for the foam
Re: Making pads
« Reply #4 on: January 06, 2006, 02:03 PM »
but its grey isnt it?
Re: Making pads
« Reply #5 on: January 06, 2006, 02:06 PM »
it'll be covered though?
Offline Waxintaxin
Re: Making pads
« Reply #6 on: January 06, 2006, 02:07 PM »
Pipe foam can come in all sorts of colours
Re: Making pads
« Reply #7 on: January 06, 2006, 02:07 PM »
not the ends
Jazzchimp
Re: Making pads
« Reply #8 on: January 06, 2006, 02:17 PM »
I think you could get a foam company to make bespoke extrusions, but the fabric seems more tricky.
Offline Nosnod
Re: Making pads
« Reply #9 on: January 06, 2006, 02:48 PM »
B & Q do a thin walled pipe lagging for 22mm dia pipes which should be OK as a top tube and one for 15mm pipe that should be OK for bars. It comes in grey so you could always dunk it in a bucket of dye the next time you are dyeing a seat! ;). They also do a black flexible version but that looks a bit thick!
Offline diesel
Re: Making pads
« Reply #10 on: January 06, 2006, 03:18 PM »
I bought a load of fabric from 'Carters' camping & leisure in Reading.
They sell it in rolls and have loads of weights and colours to choose from.
Only problem I can think you might have is that its coated so that its water-proof, this might be a problem getting the inks to adhere to it (best bet get a sample done first).
Hope that helps
Dan
