976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 03:33 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  redline flite crank
Author Topic: redline flite crank  (Read 2090 times)
Offline stu27
redline flite crank
« on: August 17, 2008, 05:00 PM »
hi,why have i got so many washers with my crank and does the spindle need to go in one way as the sealed bearings seem to only go on to it one way and if someone can tell me how to fit it you would make me happy
antiquebmx
Re: redline flite crank
« Reply #1 on: August 17, 2008, 05:04 PM »
hi mate
yes the spindle will go in one way, and you should have a lock nut for the other side,  washers are to line up the cranks arms and chainwheel to freewheel  :daumenhoch:
Offline stu27
« Reply #2 on: August 17, 2008, 05:07 PM »
i havent got a locknut but i have got two ccountersunk bolts with green paint on and two shorter bolts with blue paint on
antiquebmx
« Reply #3 on: August 17, 2008, 05:11 PM »
sorry mate what cranks have you got exactly??
antiquebmx
« Reply #4 on: August 17, 2008, 05:26 PM »
Twin pinch..
ahh I better shut up then ,ive not fitted those before  :-X
Offline Gary72
« Reply #5 on: August 17, 2008, 05:35 PM »
Not got twin pinch, but on mine the spindle had some grooves on one side, drive side and only after fitting once noticed this and that the splines were longer on one side, in the tech and rest stickies think there is a fitting guide. :daumenhoch:
steve Beech TA
« Reply #6 on: August 17, 2008, 05:37 PM »
That made me laugh  :2funny:, i started to read from the top and i was just thinking i never had a lock nut with mine? :daumenhoch:
Offline stu27
« Reply #7 on: August 17, 2008, 05:41 PM »
thanks everyone
steve Beech TA
« Reply #8 on: August 17, 2008, 05:45 PM »
I have fitted two set's and i dont know if it was luck but i never had a prob. I put it together out of the frame first to see how it whent together, then when i had worked out what went where i then re did it in the frame. from memory i think the spindle went in from the opposite side of the chain wheel. then use the spacers to line up as said earlier. sorry i cant be much more help. put a bit of grease on the bearing cups before fitting them as they can be a pain to fit. a rubber mallet will help  :daumenhoch:
Offline stu27
« Reply #9 on: August 17, 2008, 05:51 PM »
i have just built it up out of the frame and i think i have got it now,i slid everything onto the side where stuff cant slide on,is a rubber mallet best for putting the bearings on iwas thinking about using some pipefitters grips and pulling the 2 bearing bits together ,like crushing them together in a vice
steve Beech TA
« Reply #10 on: August 17, 2008, 07:26 PM »
If you do that it may scratch the casings, some peeps have done it far more than me and made things to put them in with, i just used grease and a rubber mallet, a bit awkward but did it withought damaging anything. as i say this may have been luck as i have never built a bike :daumenhoch:
Offline stu27
« Reply #11 on: August 17, 2008, 11:07 PM »
just brought one,thanks
Offline stu27
« Reply #12 on: August 18, 2008, 08:58 PM »
thanks for that haro-os-boy,any probs and i will be in touch
