976300 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 27, 2026, 08:56 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Profile Bearings
Author Topic: Profile Bearings  (Read 2331 times)
virtualmeuk
Profile Bearings
« on: September 10, 2008, 09:42 PM »
Hi All
Can anyone tell me what size and where i go for some gen 2 profile crank bearings.
The spindle is 19mm and the inside of the cups appear to be 41.3mm Not sure what thickness i need and what actual outside diameter bearings i need. In a hurry as well as its for the bike i am building for Macmillan on the 21st. All mad panic now as i have left it till the last minute  :tickedoff: :uglystupid2:
Offline Gary72
Re: Profile Bearings
« Reply #1 on: September 10, 2008, 09:46 PM »
have you got the old bearings, if you have there should be a ref no. on the side something like    6004 2rs.
The 6004 refers to the bearing size and the 2rs refers to the no of rubber seals. If you put the 6004 number into ebay some should come up.
virtualmeuk
« Reply #2 on: September 10, 2008, 09:48 PM »
Sadly no. All i have are crank arms, spindle, bolts and cups :'(
steve
« Reply #3 on: September 11, 2008, 12:00 AM »
they are imperial bearings
3/4, not 19mm, they are 19.050mm, which is 3/4 of an inch
virtualmeuk
« Reply #4 on: September 11, 2008, 08:43 AM »
Cool. Thanks for the info. Any idea what size the outside needs to be and the thickness?
Steve
Offline Gary72
« Reply #5 on: September 12, 2008, 12:41 PM »
Think its normally 12mm thick and 42mm diameter?
Offline Gary72
« Reply #6 on: September 13, 2008, 09:58 PM »
Right got some sitting on my desk, (Thanks Mr.Chubs) the bearing no. is R12-RS.
None on UK ebay, like someone said above US imperial bearings, could ship 50 in for a about a £1 a bearing :shocked: Alans ask's £16 for 2 bearings and a spacer tube or about £19 for a coloured Mid BB kit.
I am going to try my local bearing shop. I have had a look on the net. Searched for R12 2RS
 http://www.bearing-king.co.uk/product/4151
 http://simplybearings.co.uk/shop/p42345/KLNJ3/42RS+(+R122RS+)+Imperial+Deep+Groove+Ball+Bearing+with+2+Rubber+Shields+0.75x1.625x0.4375+inch/product_info.html
http://shop.ebay.co.uk/items/__r12-2rs_W0QQ_nkwZr12Q2d2rsQQLHQ5fAvailToZ3QQ_armZ1QQ_armmZ63QQ_fromfsbZ0QQ_ruuZhttpQ3aQ2fQ2fshopQ2eebayQ2ecoQ2eukQ2fitemsQ2fQ5fQ5fr12Q2d2rsQ5fW0Q51Q51Q5fnkwQ5Ar12Q512d2rsQ51Q51Q5farrQ5A1Q51Q51Q5ffromfsbQ5A0
Gary
« Reply #7 on: September 13, 2008, 10:04 PM »
Be sure to buy yourself german, british or japanese bearing NOT chinese and they'll last a whole lot longer......  Last time I got some I think they were about £8 each for top quality ones   :)
steve
« Reply #8 on: September 14, 2008, 04:42 AM »
try midland bearings, for they are the cheapest bearing supplier in the whole world
and when you ring up, they know what you are talking about
especially when you can now cross reference the quoted bearing number with their listing
r12 2rs
http://www.midlandbearings.com/Rseries.htm
so when you ring up say
-hello, I would like to purchase some 'R' series bearings
i'd like 'x' amount of R12 2 RS please
they will say, ok thats the 3/4 'bore' = 'i-d'=inner dimension/  1-5/8  o-d ,= outer dimension / 7/16 overal width.
you say yes please, thank you.
oh and with regards the spacer doobery, you simply find a bit of old tubeing, that has a bore of 19.050 - 3/4 inch, buy a 2.99 pipe slice or pipe cutter, and make 10
-plus you can 'dial your bb in, so the bearings won't crush - ie old seat post tube 22.2, which is an imperial measure ment has the 3/4 inner bore
-plus if you go to a motor factors, you can buy ''cam bucket shims' with the 3/4 bore - id' and get the chain line stupidly correct as they are o.osmiidge plus the innner spacer tightness can be gotten rid of
ok so i am bored and can't sleep, :LolLolLolLol:
« Last Edit: September 14, 2008, 04:54 AM by steve »
« Reply #9 on: September 14, 2008, 09:28 PM »
steve thats the first post that has made sense mate lol  :P
theres a bearing shop in grays right opp grays football stadium
steve
« Reply #10 on: September 15, 2008, 02:51 PM »
ok, so i am not rambling on now, nut
TAKE NOTE - BEWARE!!!!!
if you take a tube spacer that came a euro bb and try fitting it into a usa bb
-they are different
also the other way around too
-one is too big one too small
-this is probablyy the reason why they get fackered up, as on the one hand the spacer is too long and the cups wont go in
-on the other the euro is too short and they pull the bearing races over as you tighten the arms
again you can pipe slice 2mm off one to fit - be careful though
lodge
« Reply #11 on: September 18, 2008, 05:53 PM »
I have priced profile bearings at bearing factors they range from 8 to 25 notes each depending on quality which is annoying because a similar size metric bearing is about 90p. You can buy six R12 2RS bearings off the bay from the states for 11 quid posted.
