976300
crissy_criss
June 29, 2026, 12:18 AM
DROPOUTS HELP!!!!!!!!!!
Topic: DROPOUTS HELP!!!!!!!!!! (Read 2051 times)
Swivel
Berm Worm
Ah feck it, go on then...
September 18, 2008, 07:11 PM »
Guys, how the hell can you increase the size of the drop outs without fooking them up or weakening the frame? I have a lovely bike which I hope to bring along on sunday but I've just for the 1st time tried fitting the wheels and they ain't going in! They are 10mm axles as they should be, but the forks are so tight that they won't fit around the inner nuts of the wheel to slot it in, and the rear is so tight, I cannot even slide in the back wheel!
Help!
Really want to take this along on sunday but need urgent advice.
Ta
Matt
Mr Nice
Re: DROPOUTS HELP!!!!!!!!!!
September 18, 2008, 07:15 PM »
I used an angle grinder on some aero reflex forks. took nice and easy had no damage
Swivel
Berm Worm
September 18, 2008, 07:29 PM »
Nope, not good, don't want to damage or fook up the chrome. All they are is TIGHT, can anyone advice how to free them up i.e. seperate the front forks and back dropouts without fooking them up or damaging the frame.
Ta
Matt
Swivel
Berm Worm
September 18, 2008, 07:39 PM »
fouronethreeoh!
September 18, 2008, 07:41 PM »
How far out are they?
Sometimes you have to "spring" the frame a bit to get a wheel in.
Are there additional washers between the hub cone nuts making the hubs too wide?
Swivel
Berm Worm
September 18, 2008, 07:49 PM »
They are out enough to not enable the 10mm axle to slot in, and the front forks are the worst offenders with not allowing the wheel in due to it being so tight, it won't go either side of the inner nuts to the hub. Must be a way of sorting this...
fouronethreeoh!
September 18, 2008, 07:55 PM »
Personally i would alter the hubs rather than the frame.
Reduce the thickness of the cone lock nuts or possibly even take them off.
If the gap is then too large, shim it back with washers.
The cone lock nuts arent essential as the wheel nuts will keep the cones locked when everything is tightened up.
ron burgundy
900 Air
September 18, 2008, 07:57 PM »
Are you saying the slots in the drop outs are not wide enough or the actual forks/rear drop outs are to narrow?
bodamus
Flip-Whip
September 18, 2008, 07:59 PM »
How about slotted 3/8" axles with the flat sides rather than the round type. Failing that gently file a small flat spot on the wheel axles where they need to go in the dropouts and you will be able to slide your wheels in without having to damage your Frame.
bodamus
Haro82
Rockwalk
September 18, 2008, 08:04 PM »
Are the hubs too wide or is the diameter of the spindles to large ?
vdubferret
September 19, 2008, 08:11 AM »
Ditto what someone has already said re doing the axles not the frame.
I would either take it to a machiners & get a gnats whisker take off the whole diameter, or just file off a tiny wedge either side with a needle file. I did it with N/S 14mm rims on my O/S 10mm Haro: it cost me a beer!
pickle
Site Supporter
My life is Radbmx
Posts: I am a geek!!
Reply #11 on:
September 19, 2008, 08:25 AM »
Matt........your forks are quite common in the way that they are meant to have the flattened axel.......just get a small file and rubb away some of the axel where the forks hit it. don't do the forks!
it's easy to do....just file a little at a time and make sure you do both sides evenly as you can.......should only take you 10 minutes
Swivel
Berm Worm
Reply #12 on:
September 19, 2008, 08:53 AM »
Sounds good lads, i'll give that a go. I will also whip it up the bike shop in a mo and speak to them also
pickle
Site Supporter
My life is Radbmx
Reply #13 on:
September 19, 2008, 08:54 AM »
if you do the file thing.....make sure you only file the axle where it hits the forks.....don't do the whole thing as you won't be able to get the nut on the threads
lazychubs
Founding Fathers
BMX Nerd
Reply #14 on:
September 19, 2008, 09:03 AM »
the nuts still go on pickle lol as ive done a few now
motomagII
Reply #15 on:
September 19, 2008, 09:05 AM »
me too i normally file axle down two opposite sides so there is still thread for nuts just done 14mmto 10mm on monday works treat
lazychubs
Founding Fathers
BMX Nerd
Reply #16 on:
September 19, 2008, 09:35 AM »
file i use a grinder lol
Swivel
Berm Worm
Reply #17 on:
September 19, 2008, 10:04 AM »
Ok sounds good lads, will give this a go and try and get up some piccy's later today
kdw712
900 Air
Reply #18 on:
September 19, 2008, 10:07 AM »
i've used the file on the axle as well to get the fit sorted
cheers Kev
{ wanted : "Red Haro Handle" brake lever
link to my trade post
