976302 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 01, 2026, 06:07 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Max Tyre pressure for Tuffs?
Author Topic: Max Tyre pressure for Tuffs?  (Read 1652 times)
Offline aerostylie
« on: November 23, 2008, 12:01 PM »
Hi folks ;)
Got a tasty set of Haro Multisurface 3 that I'd like to have caressing my tuffs. The max PSI is 100 but I've heard that tyres will only go so far before popping on tuffs?
So, before I re-create the big bang theory in B'ham, what's the max I can go on placcy tuffs?
Paul
« Last Edit: November 23, 2008, 12:56 PM by aerostylie »
Vans Style
Offline aerostylie
Re: Max Tyre pressure for Tuffs?
« Reply #1 on: November 23, 2008, 01:00 PM »
Thanks Bru, that sounds safe enough :daumenhoch:
Bet someone will up the ante on 60psi ::)
Vans Style
Offline Rombloke
  • do one
« Reply #2 on: November 24, 2008, 07:41 PM »
657psi
haro, how do you do
« Reply #3 on: November 24, 2008, 07:51 PM »
depends on the tyre.
ive blown a tyre off the rim jumping off a 2ft wall, but that was with cheap tyres, at 45 psi.
i have run primo walls, at 60 psi on tuffs with no problem, but then again, im not exactly dropping in from 100ft quarterpipes.
spesh
« Reply #4 on: November 24, 2008, 08:06 PM »
i ran my haro,s at 75psi on tuffs and it was fine(im a fat 18st fooker!)
Offline Rombloke
  • do one
« Reply #5 on: November 24, 2008, 09:30 PM »
657psi
Fooking hell Dave bit excessive that!  :shocked: :shocked:  :LolLolLolLol: :LolLolLolLol:
Bru  :daumenhoch:
i did once run mine at 968psi but i found it a little hard, and the tyres rubbed on the frame and forks
haro, how do you do
