976302 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 01, 2026, 04:54 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Bent Shaft
Author Topic: Bent Shaft  (Read 4071 times)
rideandy
Bent Shaft
« on: December 13, 2008, 03:41 PM »
Chaps
I have just got hold of some Landing Gear forks, shipped from the states from the us.
I have noticed that the main shaft is slightly bent, can this be sorted and if so whats the best way??
dan-dare
Re: Bent Shaft
« Reply #1 on: December 13, 2008, 04:02 PM »
lodge
Re: Bent Shaft
« Reply #2 on: December 13, 2008, 05:11 PM »
I know this a bit brutal but I have straightened forks by smashing the front wheel into a wall, obviously turning your bars 180 degrees if need be.
I wouldn'r recommend this for a serious rider though.
dan-dare
Re: Bent Shaft
« Reply #3 on: December 13, 2008, 05:14 PM »
Old school, I like it! :daumenhoch:
Re: Bent Shaft
« Reply #4 on: December 13, 2008, 05:14 PM »
andy get a picture up of the forks.
rideandy
Re: Bent Shaft
« Reply #5 on: December 13, 2008, 07:04 PM »
rideandy
Re: Bent Shaft
« Reply #6 on: December 13, 2008, 07:06 PM »
Cheers, might have to try it , on last resort!
rideandy
Re: Bent Shaft
« Reply #7 on: December 13, 2008, 07:07 PM »
I will defo post up pic tomorrow.
Thanks chaps
rideandy
Re: Bent Shaft
« Reply #8 on: December 14, 2008, 04:14 PM »
As I said on my other thread,these do need some work!
Here they are.
Can they be saved??
dan-dare
Re: Bent Shaft
« Reply #9 on: December 14, 2008, 06:23 PM »
http://www.uktools.com/product_info.php?cPath=67_930&products_id=4017
Go gently, bentley. :daumenhoch:
Cheers, nice price!!! lol
Yeah don't buy it, try to find someone that has one, and will do it for you.
Offline billstup
Re: Bent Shaft
« Reply #10 on: December 14, 2008, 08:21 PM »
Take them to a collage that teaches plumbing, they will have a hydrauic mild steel tube bender that would straighten them  :daumenhoch:
spillers#1
Re: Bent Shaft
« Reply #11 on: December 14, 2008, 08:30 PM »
There not T.J. baldwins old ones are yhey ;)
rideandy
Re: Bent Shaft
« Reply #12 on: December 14, 2008, 08:31 PM »
Yeah to much for the one job.
rideandy
Re: Bent Shaft
« Reply #13 on: December 14, 2008, 08:33 PM »
Great idea.
rideandy
Re: Bent Shaft
« Reply #14 on: December 14, 2008, 08:36 PM »
I had they shipped from the US.
They would be rammed up T.J's arse if he was local!!
dan-dare
Re: Bent Shaft
« Reply #15 on: December 14, 2008, 08:38 PM »
sphincter muscles can do amazing things. :'(
Offline jT Racing
  • i like bikes. :/
Re: Bent Shaft
« Reply #16 on: December 14, 2008, 08:46 PM »
i'm about to have a go at this at work this week on some prolite forks, i use one of these on a daily basis
i'll let you know how it go's.
ding dong
rideandy
Re: Bent Shaft
« Reply #17 on: December 14, 2008, 08:47 PM »
rideandy
Re: Bent Shaft
« Reply #18 on: December 14, 2008, 08:49 PM »
Wtf is that?
Offline jT Racing
  • i like bikes. :/
Re: Bent Shaft
« Reply #19 on: December 14, 2008, 08:50 PM »
100 ton press brake. big hydraulic squashy thing.
ding dong
rideandy
Re: Bent Shaft
« Reply #20 on: December 14, 2008, 09:06 PM »
Yeah please let me know how you get on with the squashy thing.
So do you think I will be able to sort my forks out or are they to bent???
telelogic
Re: Bent Shaft
« Reply #21 on: December 15, 2008, 12:33 PM »
what kind of wall do you recomend? ;)
lodge
Re: Bent Shaft
« Reply #22 on: December 15, 2008, 01:08 PM »
Brick but make sure the mortar has fully dried you might need to use a moisture meter to establish that the mortar is dry enough to take the envisaged impact.
If your not sure employ a chartered building surveyor and request a certificate before commencing to smash the bike into the chosen wall.
Bettyswallocks
Re: Bent Shaft
« Reply #23 on: December 15, 2008, 01:21 PM »
Watch your speed if you give the wall method of fork sraightening a go, too fast and this could happen...  :D
Forks are straight though... job done...  :daumenhoch:
lodge
Re: Bent Shaft
« Reply #24 on: December 15, 2008, 01:25 PM »
Also good if you want to shorten your wheelbase :daumenhoch:
