976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 02, 2026, 12:40 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  skyway tuff 2's with metal hub
Author Topic: skyway tuff 2's with metal hub  (Read 2356 times)
t4turtle2000
« on: January 14, 2009, 10:40 PM »
If you have the metal hub tuff 2's with a coaster brake can they be converted to a real freewheell'thanks
Re: skyway tuff 2's with metal hub
« Reply #1 on: January 14, 2009, 11:22 PM »
They can, there was a dongle you could add somewhere that makes them freewheel which you used to be able to buy from your local bike shop.
Another 'i know it can be done but not sure where you get the bit' post there, sorry.
« Reply #2 on: January 14, 2009, 11:27 PM »
Keep the coaster - loads of tyre shreddin fun  :LolLolLolLol:
« Reply #3 on: January 15, 2009, 06:10 AM »
Yes it can be done, the early Tuff II had steel front hubs & steel rear hubs with a cassette type freewheel, I had some of these & the freewheel was not working so I removed it & fitted a Suntour coaster break, so the shell is the same, its just finding one of these early cassette freewheels is the problem  :-\
Your other option would be to fit a freecoaster freewheel which you can get, its made by ACS, I may even have one somewhere  ???
http://www.vert-ego.com/main.htm
Click on the Freewheel / Coaster adapters link & its at the bottom.
Or removed the hub & fit some replacement Alloy hubs which take a screw on freewheel.
« Last Edit: January 15, 2009, 06:11 AM by wish id kept my TA »
« Reply #4 on: January 15, 2009, 12:18 PM »
Or get one of these from Alans, only a tenner plus post and dead easy to fit...
http://www.alansbmx.com/product_info.php?cPath=116_120&products_id=1584
Rooonga
« Reply #5 on: January 15, 2009, 01:16 PM »
How does that thing work???
« Reply #6 on: January 15, 2009, 06:13 PM »
You replace the one on the coaster where the sprocket is fixed & screw a freewheel onto it  :daumenhoch:
Rooonga
« Reply #7 on: January 15, 2009, 06:57 PM »
Ahh - now I see.
