976303
crissy_criss
July 03, 2026, 02:41 PM
STUCK HEADSET CUP
Topic: STUCK HEADSET CUP (Read 1793 times)
HEYWOOD BMX
STUCK HEADSET CUP
February 24, 2009, 06:44 PM »
Been hammering the crap out of a cup all day.Bugger won`t budge.I`ve left it for a few hours after giving it a good squirt of GT85 but still no joy.Any hints/tips please?
Voodoocars
Re: STUCK HEADSET CUP
February 24, 2009, 08:45 PM »
Hit it harder. But dont miss and hit your hand like I did last night. Twice.
meticulous
Berm Worm
February 24, 2009, 08:50 PM »
if i get chance i will call 2moz, was going to do today but i forgot the bolt in that seat post clamp, i have some big chisels and a fookin big hamer in my van, other than that try heating the frame with a heat gun ( not hairdrier) might expand it enough for it to slip out....
R.I.P O.M. Far short of the finish line...
MartyC
Berm Worm
February 25, 2009, 12:19 PM »
Use an old steel seatpost and hammer and work your way round the cup on opposite sides with each strike
JT71
February 25, 2009, 12:27 PM »
i use a 3/8" drive extension bar to insert through the headtube and knock it out from the inside, had a few tight ones but they usually come out if you hit it hard enough.
pickle
Site Supporter
My life is Radbmx
Posts: I am a geek!!
February 25, 2009, 12:35 PM »
same as above.......use an extension bar and go round the cup hitting it like it was a fat cat banker
HEYWOOD BMX
February 25, 2009, 12:50 PM »
Cheers fellas.
All sorted by Meticus
thecrooch
February 25, 2009, 01:02 PM »
take it to your LBS and they can twat it using the proper tools!
you need one of these... they are brilliant!
http://www.wiggle.co.uk/p/Cycle/7/Cyclus_Headset_Cup_Remover/5300003487/
Proper tools for a proper job young man!
STUCK HEADSET CUP
