976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 04, 2026, 02:27 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Advise: Polishing using a Dremel/Draper Multitool?
Author Topic: Advise: Polishing using a Dremel/Draper Multitool?  (Read 2952 times)
Offline 20to26
« on: March 23, 2009, 06:31 PM »
Anybody got some advise on the steps to getting a grubby silver stem transformed into a polished gleaming beauty?
I've started with 1500 grit wet to glean it up, and now what are the best attachments to use & do I do it with liberal applications of Autosol?
Thanks!
buzzlightyear05
Re: Advise: Polishing using a Dremel/Draper Multitool?
« Reply #1 on: March 23, 2009, 06:35 PM »
I found after using a fine wet and dry using a felt wheel on the dremel with plenty of brasso and lowest speed gives great results. Dont let it dry out though makes it go dull again.
Offline Gary72
Offline 20to26
« Reply #3 on: March 24, 2009, 01:34 PM »
merci.
« Reply #4 on: March 24, 2009, 04:19 PM »
get the blue polishing compound, works a treat :daumenhoch:
neiljonarcus
« Reply #5 on: March 24, 2009, 08:51 PM »
best  thing  for  polishing  is  new  skin  for  your fingers
Offline 20to26
« Reply #6 on: March 24, 2009, 08:57 PM »
now that's what I'm talking about - I guess it helps by starting with a minty condition stem huh!
neiljonarcus
« Reply #7 on: March 25, 2009, 06:36 AM »
yes  it  does  but  with  the  right  prep  and  a  lovely soft  mop  on a  bench  grinder  and  blue  soap  for  high  shine  finish  you  can  get   this  finish
http://www.radbmx.co.uk/forum/index.php'topic=82235.0
sid1972
« Reply #8 on: March 25, 2009, 09:54 PM »
ship the puppie to me and I will get it done in the metal workshop of our tech department... all the gear there you could ever want!
Offline Gary72
« Reply #9 on: March 27, 2009, 09:53 PM »
Used the kit tonight, Oven pride 1st, then wet/dry, then both wheels.
Black to Bling
no need to do the bottom of the post, not seen. :daumenhoch:
