976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 03:41 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  SKYWAY ALI HUB REPLACMENT
Author Topic: SKYWAY ALI HUB REPLACMENT  (Read 1432 times)
Offline PRO THUNDER
  • Wanted. Huffy Pro Thunder bikes and parts.
« on: April 23, 2009, 02:10 PM »
I'VE GOT A COUPLE OF PAIRS OF ALI HUB BLACK SKYWAYS FOR RESTO, ONE SET SEEMS TO BE OK BUT THE OTHER SET ARE ALL PUSHED IN FROM BEING OVER TIGHTENED.  I'VE GOT THE REPLACMENT HUB KIT TO REPLACE THEM WITH BUT NEED TO KNOW IF I SHOULD USE THE NUTS AND BOLTS THAT COME WITH THE KIT OR SHOULD I RE-RIVET THEM, IF SO WHAT AND WHERE CAN I GET THE RIVETS FROM.
Re: SKYWAY ALI HUB REPLACMENT
« Reply #1 on: April 23, 2009, 03:19 PM »
If the hubs are just pushed in, first try to get them pushed out, it has been done  :daumenhoch:
If this does not work & you bolt a replacement hub in, you will devalue your wheels, so do this as a last resort   :)
virtualmeuk
« Reply #2 on: April 23, 2009, 03:24 PM »
I have a special widget for pulling the hubs out!
I will PM you :daumenhoch:
Offline PRO THUNDER
« Reply #3 on: April 23, 2009, 04:52 PM »
It looks like the hubs have been re-riveted in the past and have been badly done.  Can you get rivets that will fit and do the job so that it won't make them look shite and de-value them? :-\
aditup 2234
« Reply #4 on: April 23, 2009, 05:15 PM »
Give JAY a shout. He has had some done in the past.
Ad  :daumenhoch:
Offline PRO THUNDER
« Reply #5 on: April 23, 2009, 05:20 PM »
Cheers Ad
If my attempt at pulling the hubs out fails I'll give him a shout. :daumenhoch:
