976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 05, 2026, 08:23 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Oldschool Frame with N/S forks ?
Author Topic: Oldschool Frame with N/S forks ?  (Read 1921 times)
oldschool rider
« on: April 29, 2009, 09:39 PM »
Ok guys I know this can be done and I'm sure there was a thread about it but I can't find it.
I would like a how to - For 1 1/8 forks into an O/S frame.
Cheers Guys.
Steve.
oldschool rider
Re: Oldschool Frame with N/S forks ?
« Reply #1 on: April 30, 2009, 09:26 AM »
Can anyone help out ?
« Reply #2 on: April 30, 2009, 09:29 AM »
you need to put all the ball bearings loose into the cups with grease  then affix the rest.
oldschool rider
« Reply #3 on: April 30, 2009, 09:32 AM »
Cheers Dan, You Da Man!
I thought that was all that was involved but wanted to check first.  :daumenhoch:
Steve.
« Reply #4 on: April 30, 2009, 09:34 AM »
i have better luck when i used the bigger ball bearings from a newer school headset
the smaller old school ones had a tad of slap   so try to find a newer race to pop the bearings from.
oldschool rider
« Reply #5 on: April 30, 2009, 09:48 AM »
Cheers Dan I will do, it's not for me it's for a mate here I will pass the message on.
Steve.
spinmaster
« Reply #6 on: April 30, 2009, 09:57 AM »
i've done this recently after seeing someone on here did it. can't find the thread but basically i put tioga beatrap 2 cups in the old frame got a unsealed 1 1/8th headset, took the bearings out of the cages, loads of grease in the cups, bearings in then used the rest of the 1/18th headset to finish off.
will look for the thread.
Offline fugazi
« Reply #7 on: April 30, 2009, 09:58 AM »
You also need to watch which cups you use as some of the more heavy duty jobbies wont allow the larger steerer tube through, beartrap 2 cups work well  :daumenhoch:
spinmaster
« Reply #8 on: April 30, 2009, 10:01 AM »
yep i was told beartrap 2 cups would be best.
here's the thread i got the idea from
http://www.radbmx.co.uk/forum/index.php'topic=72502.0
oldschool rider
« Reply #9 on: April 30, 2009, 10:21 AM »
 :daumenhoch: Cheers for link to thread, I knew I had seen one somewhere.
Steve.
