976303 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss July 07, 2026, 12:42 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  can you get the sealed bearings out....
Author Topic: can you get the sealed bearings out....  (Read 3538 times)
« on: June 17, 2009, 08:19 PM »
of suntour hubs, it looks like they could be pressed in?
thanks,....
HEYWOOD BMX
Re: can you get the sealed bearings out....
« Reply #1 on: June 17, 2009, 08:26 PM »
 :) Should be able to.Most bike bearings are pressed in & have the size etc stamped onto them if you need to source replacements...
« Reply #2 on: June 17, 2009, 08:28 PM »
thanks james, but you cannot get a screw driver in to tap it out, as there is no lip for your chisel/screw driver to get hold of....   :'(
« Reply #3 on: June 17, 2009, 08:32 PM »
use the axle to tap em out but make sure ya dont damage the axle  when hitting it :daumenhoch:
« Reply #4 on: June 17, 2009, 08:37 PM »
the bearing centre and hub centre are both the same size and butt up to one another so you cannot geta grip onto it....
« Reply #5 on: June 17, 2009, 08:50 PM »
I know what you are saying...  it's a very poor design.
Buy a set of Suzue, they were designed by a person with a brain.
Offline kuwahero
    • Western Titans
« Reply #6 on: June 17, 2009, 09:00 PM »
I have the same problem. I think you need a small bearing puller but dont know where to get one.
I removed the shields on the outside, flushed them with GT85 and packed them with grease. they run ok at the mo but will need replacing once I can find a way to remove them
dan-dare
« Reply #7 on: June 17, 2009, 09:11 PM »
As above, the spindle has a shoulder in the centre. So you can tap one side out, followed by the other. Put an old wheel nut on the spindle to tap it, or use a hide hammer. :daumenhoch:
snav69
« Reply #8 on: June 17, 2009, 09:17 PM »
I came up with my own way of removing them  :)
Get one of these expanding bolts
Insert it till tight then nip it up with a spanner
Then twat it out with a small extension bar
Worked a treat for me and then i replaced them with 6001RS sealed bearings
Thats an old Suzue hub i've just used in the pictures for demontration, I did it this way to the Araya Aero's i sold to motomagII on here that had sealed Suntours  :)
 :coolsmiley:
Offline kuwahero
    • Western Titans
« Reply #9 on: June 17, 2009, 09:19 PM »
spindle doesnt have a shoulder as you can remove it. from the hub with the bearings still in place.
top man snav guess I will be servicing them at the weekend then.  ;)
« Last Edit: June 17, 2009, 09:21 PM by kuwahero »
« Reply #10 on: June 17, 2009, 09:50 PM »
Getting sealed bearings out on hubs is a pot of p*ss! i usually just undo one of the hub bolts then knock out the axle with a plastic or wooden malet and if one of the bearings stay put in there then i use a drift on it :daumenhoch:
dan-dare
« Reply #11 on: June 17, 2009, 09:53 PM »
Your right dude, I'm thinking suzue. ;D
« Reply #12 on: June 17, 2009, 10:57 PM »
snav top idea fella  :daumenhoch:
Offline Steve P
« Reply #13 on: June 18, 2009, 12:12 AM »
I second that ... nice idea  :daumenhoch:
« Reply #14 on: June 18, 2009, 12:24 AM »
D'you know Snav ?  ???
People don't like clever clogs  :yahoo_silent:
but you're alright in my book Paul  :D
Not as daft as ya look  :-X
« Reply #15 on: June 18, 2009, 07:17 AM »
excellant snav, i'm too blond to of thought of that.....       ;)
snav69
« Reply #16 on: June 18, 2009, 08:13 AM »
 :D  :crazy2:
« Reply #17 on: June 18, 2009, 03:38 PM »
Blimey, for a Wiganer that's not a bad idea  :LolLolLolLol:
snav69
« Reply #18 on: June 18, 2009, 03:42 PM »
 :knuppel2:  :crazy2:
