976305 Posts in 138996 Topics by 6433 Members - Latest Member: AntYeo1 July 14, 2026, 08:59 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  acs z rim spoke size
Author Topic: acs z rim spoke size  (Read 6011 times)
Offline oldschoolib
« on: October 14, 2009, 11:35 AM »
can anyone tell me the exact size spokes i need two people have told me two different sizes
Offline Peter J
  • I have issues
Re: acs z rim spoke size
« Reply #1 on: October 14, 2009, 11:41 AM »
What hubs are you using with them ?
Offline phantom photon
« Reply #2 on: October 14, 2009, 12:51 PM »
I use 194mm spokes with small flange hubs  :daumenhoch:
ozone
« Reply #3 on: October 14, 2009, 01:47 PM »
I used 184s with high flange hubs.  Well my wheel builder did ;D  Make sure you get long nipples  >:D as Z rims are a lot thicker than alloy/steel rims and short nips struggle to reach the threads 8)
Offline oldschoolib
« Reply #4 on: October 14, 2009, 07:22 PM »
ive got two sets to built both with acs hubs, thanks for the replies will defo use long nipples  :2funny:
« Reply #5 on: October 14, 2009, 08:45 PM »
deffo 194's with acs hubs
Offline oldschoolib
« Reply #6 on: October 14, 2009, 09:19 PM »
bigsman
« Reply #7 on: October 15, 2009, 09:36 AM »
Not wanting to confuse things but is the info provided 100%?
...I built up some Zeds recently (using Acs hubs) and after speaking to Stidds and taking measurements I bought and built them up, using 182 length spokes??  Bear in mind that zeds have that raised centre on the rim and that was what made the length shorter than I expected.  Just throwing that out there to avoid any chance of getting the wrong thing like  :)
ozone
« Reply #8 on: October 15, 2009, 10:11 AM »
The guy who built my wheels does it for a living so I'm 100% sure he knows what he is talking about.
He used 184s...
« Reply #9 on: October 15, 2009, 10:31 AM »
It all depends on the pattern you use, either a 3 cross or 4 cross. Obviously a 4 cross pattern would require longer spokes i.e. 194mm  :daumenhoch:
bigsman
« Reply #10 on: October 15, 2009, 10:50 AM »
He used 184s...
[/quote]
Impressive as that is I built my own with my own eyes and hands and so there was probably less chance of a communication breakdown or mistake as a result.
I used 182s for a 3 cross lace...
To be fair you could probably get away with 184s  :LolLolLolLol:
Offline oldschoolib
« Reply #11 on: October 15, 2009, 10:18 PM »
this not helping from the post ive got 194 , 184 and 182 i starated with 2 now ive got 3 come on please whats the standard anyone out there ive got 2 sets of rims and 4 sets of hubs i need these spoked
« Reply #12 on: October 15, 2009, 11:21 PM »
It all depends on what size the hubs are and what lacing pattern you intend to do.
If you have a set of vernier calipers and a tape measure then I can let know the measurements that are needed to be taken.  When you have the measurements I can calculate the exact spoke length needed as I did with bigsman.
Offline Peter J
  • I have issues
« Reply #13 on: October 15, 2009, 11:38 PM »
Sorry to throw an other spanner in the works but don't you also need "washers" on the inside of the rims as well  ???
http://www.radbmx.co.uk/forum/index.php'topic=70280.0
Offline Faze7-Ade
« Reply #14 on: October 16, 2009, 05:57 AM »
I rebuilt my 36 spoke mike buff z-rims with small flange ACS hubs with 4 cross pattern using a 184mm spoke using the original long spoke nipples. I just about got away with it (the spokes were too short) but would not recommend you use this combination of spokes with 4 cross. I didn't have washers as the original wheels came without them.
So if you have acs small flange hus and want to go 3 cross then 182mm or 184mm is the length you want (there is so little difference in the length it won't really matter too much), and if you're going 4 cross 194mm is the length you want  :daumenhoch:
« Last Edit: October 16, 2009, 06:02 AM by Faze7-Ade »
« Reply #15 on: October 16, 2009, 10:06 AM »
What that man said  :daumenhoch:
Offline oldschoolib
« Reply #16 on: October 16, 2009, 06:49 PM »
ok im going to go with 184s long nipples 3 star on 1 and 4 star on the others cheers for the heads up fellas
