976308 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 17, 2026, 06:48 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Rims - how hard
Author Topic: Rims - how hard  (Read 2368 times)
paullightowler
Rims - how hard
« on: November 17, 2009, 08:36 PM »
Guys
I was going to strip my Araya 7 rims ( Oven Pride ).
How easy and how time consuming is polishing them ?
Is it a good job ?
Is it better to send them to Custom Colour ?
Offline Bigfrawg
Re: Rims - how hard
« Reply #1 on: November 17, 2009, 08:40 PM »
depends how patient you are and what polishing equipment you have , if it was me i would get paul at custom colour to tackle them  :daumenhoch:
Re: Rims - how hard
« Reply #2 on: November 17, 2009, 08:52 PM »
i fooked up a pair of araya's with ovenpride....  it ate into the alloy rendering them un-anodisable, so be carefull...
paullightowler
Re: Rims - how hard
« Reply #3 on: November 17, 2009, 09:08 PM »
There's a trend in the replies appearing !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: Rims - how hard
« Reply #4 on: November 17, 2009, 09:24 PM »
For the £15/20 Paul charges at CC it ain't worth messing with them , he will strip them and mirror polish them  8)  He also prefers to do the prep work himself as caustic can be a nightmare if you leave it on too long , affecting the final finish etc  ;)
He is mad busy at the moment though, so i hope you are not in a mad rush  ???
Re: Rims - how hard
« Reply #5 on: November 17, 2009, 09:26 PM »
Rims-how hard?  ???
paullightowler
Re: Rims - how hard
« Reply #6 on: November 17, 2009, 09:37 PM »
Thats it my mind is made up - Paul it is !
Offline GTnumber1
Re: Rims - how hard
« Reply #7 on: November 17, 2009, 09:59 PM »
for £20 mate send them to paul, i did my last set and its a fooking long process, here it is if you decide to give it a go, but be warned you wont be able to knock one out after  :2funny: :2funny: :2funny:
1. oven pride
2. depending how bad the sidewalls are you can start with 80 or 150 using a block
3. 240, 320, 400, 500, 800,
4. 1000 avlon pad wet, 1200 wet, 1500 wet, 2000 wet, 3000 pad wet
5. brasso
6. auto sol all over the rim and polish using a machine ( i use a car polisher/ compound machine)
they should come out flat no marks and gleaming like glass   :4_17_5:
hope that helps
paullightowler
Re: Rims - how hard
« Reply #8 on: November 17, 2009, 10:11 PM »
AAAAAAAAAAAAAAAAAAArrrrrrrrrrrrrrrrggggggggggggggghhhhhhhhhhhhhhhhhhhhh    :D
No way !!!!!!!!!!!!!!!
Re: Rims - how hard
« Reply #9 on: November 18, 2009, 02:07 PM »
For all the hassle it will take you, send them to an experienced polisher and one that understands how important they are so they don't polish our the stamping or polished the edges off.  Look at what he did for Gashead....
