976008 Posts in 138958 Topics by 6401 Members - Latest Member: Miltz83 September 10, 2025, 12:29 PM
RADBMX.CO.UK  |  Old School BMX 1980 - 1988  |  Old School Freestyle (frame stands and kickturns galore!)  |  tyre pressure
Author Topic: tyre pressure  (Read 4331 times)
andy irwin
tyre pressure
« on: May 01, 2006, 02:39 PM »
Ok this sounds daft but what is a good tyre pressure for old school street? I am told it is 70 psi but I dont remember it feeling like I had solid tyres bitd. I know this isn't as good as Andy Shohara's thread but what is? :LolLolLolLol:
Ta muchley  Andy
« Last Edit: May 01, 2006, 02:43 PM by jeff spicoli »
Offline ORB
Re: tyre pressure
« Reply #1 on: May 01, 2006, 02:40 PM »
i run about 45 psi on tuffs wearing Oddy barefeet
12
andy irwin
Re: tyre pressure
« Reply #2 on: May 01, 2006, 02:42 PM »
running spoked wheels with miricle tyres  I think they are called ,on the dk dayton.
« Last Edit: May 01, 2006, 02:45 PM by jeff spicoli »
weston
Re: tyre pressure
« Reply #3 on: May 01, 2006, 02:44 PM »
i used to run about 45psi back in the day but i only weighed half as much as i do now
retrorider.u.k
Re: tyre pressure
« Reply #4 on: May 01, 2006, 02:47 PM »
bitd would run 60-70 on ground and 50 on ramps
Re: tyre pressure
« Reply #5 on: May 01, 2006, 02:48 PM »
70 psi.
stuff one tyre inside of another for extra hardness / durability
andy irwin
Re: tyre pressure
« Reply #6 on: May 01, 2006, 02:54 PM »
I must be getting old then  :LolLolLolLol: it was never an issue bitd and it never felt this hard . Oh well rector wrist guards it is then. ;D
Offline Rombloke
  • do one
Re: tyre pressure
« Reply #7 on: May 01, 2006, 02:57 PM »
andy those tyres are ggod for 110 psi
i personally run 75-80....its a little less strenuous on older wrists.
for wooden parks you can run higher pressures, but concrete parks and street you can drop the pressure a tad
Dave
haro, how do you do
andy irwin
Re: tyre pressure
« Reply #8 on: May 01, 2006, 03:03 PM »
Dave
Ok Will do  :daumenhoch:
motomagII
Re: tyre pressure
« Reply #9 on: May 01, 2006, 06:52 PM »
i tend to put about 70 in mine and landings when i do manage to get the 34lbs of bike off the ground can be hard on the wrists but more pressure equals less chance of wheel damage so get em pumped
Jazzchimp
Re: tyre pressure
« Reply #10 on: May 01, 2006, 10:39 PM »
I run about 30! and I seem to be on my own! but look at my landing and I don't get close to touching the rim
« Last Edit: May 01, 2006, 10:41 PM by Jazzchimp »
RADHAB
Re: tyre pressure
« Reply #11 on: May 01, 2006, 11:43 PM »
Andy i ride loads of street and run my tyres the same pressure for parks, street, Bones bowl anywhere reallly always keep em at 90psi or there abouts. Ran the same pressure on HP peregrine wheels from 1988-91 prior to that cant remember probably no more than 50. Street riding relies on a certain amount of speed so harder tyres, sealed bearings= more speed less effort!
andy irwin
Re: tyre pressure
« Reply #12 on: May 02, 2006, 06:03 PM »
Thanks a lot for that  , Gonna get pumping then and give em a go at 90 psi. I think at my weight 30psi would be to soft .What do you weigh jazzchimp?. :daumenhoch:
Jazzchimp
Re: tyre pressure
« Reply #13 on: May 02, 2006, 07:15 PM »
Not sure, I think it's 69 kilos. To be honest I do it by the old thumb on tyre technique
Re: tyre pressure
« Reply #14 on: May 02, 2006, 08:35 PM »
Boys.....  pump 'em up!!
I run 110psi in mine front and rear, although I do let a little out when i'm riding concrete (to save my wrists a wee bit), but never lower than 90.  That said, I'm in no way light  :-[    I go 14.5 stone these days.....
I think the harsh ride is as much to do with modern stiff frames and forks and improvements in rim design.  Not to mention old age  ;D
andy irwin
Re: tyre pressure
« Reply #15 on: May 02, 2006, 09:00 PM »
gotcha :daumenhoch:
andy irwin
Re: tyre pressure
« Reply #16 on: May 02, 2006, 09:50 PM »
I aint that smooth
« Last Edit: May 02, 2006, 09:52 PM by jeff spicoli »
RADHAB
Re: tyre pressure
« Reply #17 on: May 03, 2006, 01:07 AM »
Rob i'm wiv you on that although 40 years old is a long way off for me :daumenhoch:
Offline tricknuts
Re: tyre pressure
« Reply #18 on: May 03, 2006, 02:32 AM »
There's a clever little formula that i invented to work out the correct tyre pressure for you. Its called the tricknuts tyre pressure law.
Take you weight in Kg subtract your age, and add this number to the product of the number of pints you can drink and the number of BMX bikes owned.
weight - age + (pints drunk x Bikes owned) = pressure in psi.
This always worked for me
andy irwin
Re: tyre pressure
« Reply #19 on: May 03, 2006, 05:36 PM »
i might try that if rad habs method dont work lol
Holmetech
Re: tyre pressure
« Reply #20 on: May 03, 2006, 06:05 PM »
I use 70psi but im on tuffs. I'd use about 90 on spokes with gloves and soft fooking grips.  :LolLolLolLol:
dirtbro
Re: tyre pressure
« Reply #21 on: May 03, 2006, 06:21 PM »
i totally agree with 80 - 90 psi front and back
Jazzchimp
Re: tyre pressure
« Reply #22 on: May 03, 2006, 10:39 PM »
Your tyres must look like balloons!!  :laugh:
andy irwin
Re: tyre pressure
« Reply #23 on: May 03, 2006, 10:45 PM »
They dont feel like balloons I know that for sure, They feel like solid rubber :LolLolLolLol:
sadowdgit
Re: tyre pressure
« Reply #24 on: May 03, 2006, 10:48 PM »
Spicolio's Head looks like a Baloon  ;D
