Fricko post
HUTCHMAN:
skyway67.....i think you've just become EVERYBODY'S new best friend. :LolLolLolLol:
BENDYCAT ELEVENTEEN:
:LolLolLolLol: true
so where abouts are you in the country
we might have to talk ;)
skyway67:
i'm in worcestershire near the safari park and severn valley railway
as i said earlier in your thread a post like aluminium would drill fairly easy ........... is it 22.2 mm ?
also the seat post damage looks straight forward as long as the metals good
would the frame be powdered after ? :)
Your about 2h48mins away from me so a courier it would be
yes it alloy - most likely 22.2
yup tube top has two cuts (not by me) and done back it the day i think - will just need a weld and then maybe another cut ?
yes being powdered up
there is one of the extra tubes that is missing a bit of welding ? and as it will be under powder, can your mate do that ? 1/4"
cheers B ;)
skyway67:
no problem
the seat post would have to be drilled out first
then the tube prepped and welded up and have the expansion slot machined in after :smiley6600:
Navigation
[0] Message Index
[*] Previous page
Go to full version
