OS brake squeal ?
<< < (2/2)
Betty:
You've answered your own question in the first post
Squeaky brakes that work, or non squeaky brakes that don't work
Kool stop pads are good and don't squeak much  :-\
oldtired:
caliper brakes?   tighten them up a bit ,get em as tight as possible without stopping the spring working,    its because the pads are grabbing the alloy not sliding over it causing the caliper to chatter ,  tis why the fibrax dont squeek,  harder compound,  you could also try some of the L shaped support brackets that rest on the frame they do help on caliper brakes, takes  the flex out of em under load .
steve69:
--- Quote from: bobbbbsy on July 01, 2012, 02:20 PM ---what london ride ??  :shocked: >:(
--- End quote ---
You was on it you plum  ::)
This thread was started last month  :LolLolLolLol:
oldtired:
 :LolLolLolLol:   tinterwebs slow up here, were still on town gas  :LolLolLolLol:
bobbbbsy:
--- Quote from: steve69 on July 01, 2012, 03:20 PM ---
--- End quote ---
--- End quote ---
was i ? ! d'oh!!  :LolLolLolLol:
Navigation
[0] Message Index
[*] Previous page
Go to full version
