976238
ludwig242
May 04, 2026, 06:47 PM
Shimano DX bearings
Topic: Shimano DX bearings (Read 1846 times)
wildon
Flip-Whip
Shimano DX bearings
June 30, 2013, 11:37 AM »
So i'm putting back together a set of DX. got all the bearings here and there are 2 different sizes. which size go where? larger ones nearer the pedal boss or the end cap end?
wildon
Flip-Whip
Re: Shimano DX bearings
June 30, 2013, 01:50 PM »
anyone?
Dannywhac
BMX Nerd
return of the whac
June 30, 2013, 02:01 PM »
Don't think I've ever seen em with two different sizes of bearings? Then again not done loads of em, think the one's I've done were 4mm bearings either side.
At a guess I'd say bigger bearings near the crank arm, small at the end cap end? Edit - check a bearing next to the runner groove on the spindle/bolt - you should be able to see in profile which size bearing will fit where
Last Edit: June 30, 2013, 02:05 PM by Dannywhac
"Listen. I don't care what you say. Chlamydia is a soup."
(Phelps, L. 2000)
wildon
Flip-Whip
June 30, 2013, 02:04 PM »
Cheers.
I built these before and got it the wrong way around as they just didnt fit right .. but forgot which way around that was. Just trying to get a heads up so i dont have to strip them down again
Rabdul06
Curb Endo
June 30, 2013, 02:25 PM »
I just built a set of DX up yesterday and the bearings were all the same size (11 in each end 22 total per pedal) ...not sure whats going on with yours?!
wildon
Flip-Whip
June 30, 2013, 02:49 PM »
fook knows then .. they came out survivor pedals
Dannywhac
BMX Nerd
return of the whac
June 30, 2013, 02:59 PM »
There's a thread on here were Pickle says he's got a pair with different size bearings, and think the big un's go on the cap end?
(Phelps, L. 2000)
wildon
Flip-Whip
June 30, 2013, 05:23 PM »
11 a side but they defo different sizes
NORTY40
Site Supporter
Berm Worm
NIL SATIS NISI OPTIMUM
July 01, 2013, 11:00 PM »
fook me ..... they look like cannon balls
I have a set of survivors on the way, should be here Wednesday so i'll check them
WANTED
: Old school BMX patches/sew on badges ...... please
wildon
Flip-Whip
July 01, 2013, 11:28 PM »
I put the larger ones in the crank end and they ok
kalex
Look Back
July 01, 2013, 11:31 PM »
i've not long repacked some dx's and all the bearings were the same size
Shimano DX bearings
