976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 17, 2026, 06:06 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  ACS Boa 10mm to 6mm spindle swap
Author Topic: ACS Boa 10mm to 6mm spindle swap  (Read 16541 times)
« on: September 06, 2013, 06:47 PM »
Heres one for all those who scooped a bargain Boa @ MK  :daumenhoch:
Important - before you start! make sure you work over a cloth / blanket as 68 tiny ball bearings will fall out as you take the brake apart!!!
Here we go ...
- Remove the front 'sealed mech' cap with your fingers. If the tiny threaded bit the cap screws onto stays in the brake and you need it out theres a tiny allen key head on the end of it to unscrew it with.
- Unscrew the mounting nuts and rear spring holder.
- Hold the front of the spindle with a spanner whilst slotting a small allen key into the holes in the rear lock nut and unscrew ( theres no allen head in those holes ... you just use it as a lever ) - REMEMBER to do this SLOWLY and over the cloth / blanket as all the ball bearings in the brake will fall out as it becomes loose.
- As you carefully remove the arms from the spindle REMEMBER the direction of the seals and the order that they are mounted in. All the seals can be re used in the spindle swap.
( I wanted to strip the arms on my brake so I popped them in a bit a Synstrip and gave them a light polish )
- Divide the bearings into 4 piles of 17. If the bearing races have dropped out of the brake arms use a blob of grease to stick them in again.
- Using a good amount of grease place the bearings back into the races on each side of each brake arm ... if you have a greasy finger this is useful for picking the bearings up. Get them roughly in position then use the small allen key again to position them... smooth the grease over to finish. This is fiddly but not as bad as it seems :-)
- Once you have done this for both sides of the brake CAREFULLY remount the new spindle getting the seals in the right position and right way round. Do the final tightening GENTLY as the bearings can easy pop out or you can mash the seals ... slow and steady :-)
- Tighten everything up and again screw the spring mount back in.
- Polish up to clean up any remains of the grease.
Job done :-)
« Last Edit: September 08, 2013, 06:00 PM by ED209 »
Offline pkripster
Re: ACS Boa axle swap
« Reply #1 on: September 06, 2013, 06:49 PM »
ask costa
« Reply #2 on: September 06, 2013, 06:49 PM »
lots of grease,they try to fall out  not hard just tricky.done loads
Offline Dannywhac
  • return of the whac
« Reply #3 on: September 06, 2013, 06:56 PM »
x2
If it's a used one, don't start to take it apart until you've got it over a bowl - them bearings shit everywhere if they're not greased. When you undo the retainer nut on the back, push the front of the axle (holding the arms in your fingers) so bearings that fall out will only come out from the bit of the brake at the rear, and from where you want them to :)
That and curse as you realise the placcy bearing seals are fooked. They'll still go back together though. Built to last them Boas  :LolLolLolLol:
« Reply #4 on: September 06, 2013, 07:05 PM »
its a new one Dannsta.
How do you get the retaining nut off the back? ... the one with the holes drilled in it?
Offline Dannywhac
« Reply #5 on: September 06, 2013, 07:12 PM »
Thats the fella - I've always used (after unscrewing the placcy front bit) a set of mole-grips on the front nut, then use either a small allan key/jewellers screwdriver in the holes on the back nut (failing that another mole-grip) on the rear nut. Basically hold the front of the Boa in place and unthread the rear nut  :daumenhoch:
Offline GavinDavis
« Reply #6 on: September 06, 2013, 07:34 PM »
Its not too bad a job to be fair Ed, I did it to a boa that I bought off Olly.
One thing I will add though in addition to the bearings going everywhere.....i think there are 68 bearings in a boalol, is to remember which way the seals go round on top of the bearings.
I made the mistake of getting it all back together, tightening it up only to watch the seals buckle and the bearings tried to exit from all angles lol.
Be on guard.....and keep your cool.....2 very important factors for the job lol
Offline chubby
  • Needs Pegs
« Reply #7 on: September 06, 2013, 07:39 PM »
Another tip is don't attempt is while looking after an 18 month old, it needs full concentration first time round  "nono"
Offline GavinDavis
« Reply #8 on: September 06, 2013, 07:41 PM »
Very good point! Lol
« Reply #9 on: September 06, 2013, 08:34 PM »
thank you one and all ... off now to tinker  :daumenhoch:
Offline chubby
  • Needs Pegs
« Reply #10 on: September 07, 2013, 01:23 PM »
you done it yet ???
« Reply #11 on: September 07, 2013, 01:40 PM »
Stripped it down.
Stripped the paint off the calipers and gave them a light polish.
Waiting for the new spindle off Costa!
Full photo story to follow.
Offline brakedancer
« Reply #12 on: September 07, 2013, 09:27 PM »
I was going to get one with 10mm spindal and drill my forks is that a bad idea....??
Offline GavinDavis
« Reply #13 on: September 08, 2013, 02:10 PM »
I would try and do the conversion before you start drilling mate, its pretty final once youve drilled
Offline brakedancer
« Reply #14 on: September 08, 2013, 02:40 PM »
is it still possible  to run a cable down for potts if i do drill them...
Offline GavinDavis
« Reply #15 on: September 08, 2013, 04:19 PM »
Hmmm I think it would be too tight to be honest.  Its tight enough with a 6mm  ;D
Offline midschooljon
    • Make Your Bones
« Reply #16 on: September 08, 2013, 04:40 PM »
Depends on the forks. My Bashy sport worked fine with fat axle, but I image some forks might struggle.
***Wanted - Cash waiting***
RAMP ROOM HOFFMAN FLASH
ELF Double Cross XL.
UGP plates and pad sets
Mid School Race Kit
Re: ACS Boa 10mm to 6mm spindle swap
« Reply #17 on: September 08, 2013, 05:59 PM »
All done  :angel: How-to uploaded  :daumenhoch:
    • Make Your Bones
« Reply #18 on: September 08, 2013, 06:03 PM »
Nice work Ed. Done a few myself and its not the most fun Ive ever had.  :LolLolLolLol:
Mid School Race Kit
« Reply #19 on: September 08, 2013, 07:54 PM »
good work ed
you can pump my air bed up anyday  big boy.
Offline GavinDavis
« Reply #20 on: September 08, 2013, 08:35 PM »
Great little thread there Ed! Top work mate  :daumenhoch:
« Reply #21 on: September 08, 2013, 10:23 PM »
good work ed
mmmmmm yes please Dan  :bow:
« Reply #22 on: September 08, 2013, 11:26 PM »
Nice thread  :daumenhoch:
Now make it sticky with your fat greasy finger  ;)
« Reply #23 on: September 09, 2013, 07:07 AM »
Ed had other plans for his greasy finger
 :surprise:
Offline oldtired
  • Dirty Old Man
« Reply #24 on: September 09, 2013, 09:56 PM »
Wadz's  boa bearings are all over the floor at T1  :LolLolLolLol:     boing!  :LolLolLolLol:
ed's  been on his sticky fingers for ages,   just run away when he says "ere sniff this "
