976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 16, 2026, 11:17 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Converting wheels from 10mm to 14mm
Author Topic: Converting wheels from 10mm to 14mm  (Read 2928 times)
Offline Michael bmx
« on: January 08, 2019, 10:22 PM »
Hi all, I have some  wheels with 10mm axle, I want to make them 14mm, they have sealed bearings, is it just a case of inserting 14mm ID (inner diameter) bearings with a 14mm axle or is there more to it?
Also which bearings do you recommend for pure speed. Thank you, any help would be great
Offline chubby
  • Needs Pegs
Re: Converting wheels from 10mm to 14mm
« Reply #1 on: January 08, 2019, 10:32 PM »
Be easier to use the thread on 10-14mm adapters mate. Had some on ages with no problem
Sent from my HTC One M9 using Tapatalk
Offline chubby
  • Needs Pegs
Offline Michael bmx
« Reply #3 on: January 09, 2019, 08:32 AM »
Thank you that's great, brought them  :daumenhoch:
Offline Midschoolfool
« Reply #4 on: January 09, 2019, 09:53 AM »
Those are very good if you are using pegs. They replace the lock nut, meaning all of the load goes onto the adapter and not your axle. They're more of a pain to fit, but well worth it in the end.
Offline Michael bmx
« Reply #5 on: January 11, 2019, 02:06 PM »
Thank you  :daumenhoch:
