Dia Comp front brake
<< < (3/3)
Bob_Acid:
What stem are you running?
davidben:
this one
https://www.extreme-direct.co.uk/bmx/stems/ruption/23852.php
oberonspacefruit:
that stem already has a potts mod.
oberonspacefruit:
Bob_Acid:
The stem has a hole in the bolt that will take both the inner and outer cable. All you do is thread it through there and attach it to the bottom of the caliper. If there is nothing on the fork to hold the cable away from the wheel use a cable tie or two.
Navigation
[0] Message Index
[*] Previous page
Go to full version
