976309 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 18, 2026, 01:12 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  DiaCompe 901 fitting
Author Topic: DiaCompe 901 fitting  (Read 1684 times)
Offline LucyLastic
« on: June 19, 2007, 09:52 AM »
Can someone supply a close up pic of a fitted 901 (back brake), please?  I don't know how to set the bit with 'PULL' written on it.  I had an 880 on before.
Big ta
Re: DiaCompe 901 fitting
« Reply #1 on: June 19, 2007, 10:09 AM »
The silver tab with "pull" on it should be pointing down Lou :daumenhoch:
Offline LucyLastic
« Reply #2 on: June 19, 2007, 10:41 AM »
How does the cable go through it, Tony?  Sorry if I'm dim here  :-[
othomas2
« Reply #3 on: June 19, 2007, 10:56 AM »
Behind the tab you should see a nut... and the bolt that that's attached to should have a hole in it to thread the cable through... tighten the nut to fix in position. Same principle as your convetional brake... hope this of some help.
othomas2
« Reply #4 on: June 19, 2007, 11:08 AM »
You should have something that looks like this running through the quick release mechanism. The hole i where the cables runs through...
Offline LucyLastic
« Reply #5 on: June 19, 2007, 11:41 AM »
Cheers Owen  :daumenhoch:.  Yup there is a nut, couldn't budge it too easily last night, will have another look at it tonight.
