976299 Posts in 138996 Topics by 6432 Members - Latest Member: crissy_criss June 24, 2026, 10:25 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Fly brakes
Author Topic: Fly brakes  (Read 3026 times)
muttley
Fly brakes
« on: June 02, 2008, 08:54 AM »
Anyone done a setup guide for them at all, or any tips  :daumenhoch:
Re: Fly brakes
« Reply #1 on: June 02, 2008, 09:01 AM »
They are the same setup as any U brake. Several ways of doing the cable routing.
The only thing Id say is to "toe in" the blocks like crazy! The brake works great even if only the front edge of the block is touching the rim, but they tend to squeal like a pig if you dont. I hate noisy brakes!
Bettyswallocks
Re: Fly brakes
« Reply #2 on: June 03, 2008, 08:04 PM »
Gonna give this a try, mine squeal like fook...  :(
Which way do you 'toe in' the blocks, toward the direction the wheel rotates?
Sorry if it sounds a dumb question...  :-[
Re: Fly brakes
« Reply #3 on: June 03, 2008, 08:10 PM »
toeing in of the blocks means that you set up the blocks so that when you pull the brake, the front edge of the blocks touch the rim first  :daumenhoch:
subversion
Re: Fly brakes
« Reply #4 on: June 03, 2008, 08:50 PM »
I usually toe in my blocks using a bit of folded cardboard to the desired thickness. put it between the back of the block & the rim. After you set up the brake & hold the brake on & pull the rim you will see the back edge of the blocks move in towards the rim with the forward motion of the wheel. If you don't toe in your blocks the back edge of the block is taking all the brake pressure from the forward motion & that's when you get chatter (yuk)...
Re: Fly brakes
« Reply #5 on: June 03, 2008, 08:53 PM »
Hey, Ian. Fire up that link to your blog with my PTFE tape trick. Im not totally sure how well it works, and the tape gets bunched up quite quickly, but when brakes are making loads of noise, anything is worth a go.
subversion
Bettyswallocks
Re: Fly brakes
« Reply #7 on: June 03, 2008, 09:03 PM »
Righto i gave it a go...
I loosened off the pads, pulled the brake on with a ten pence piece under the back edge of the pads and tightened em back up.
Just been round the block on the bike, still a slight squeak but nowhere near the racket i was used to...
Cheers for the tip...  :daumenhoch:
Bettyswallocks
Re: Fly brakes
« Reply #8 on: June 03, 2008, 09:06 PM »
http://subversionbmxblog.blogspot.com/2006/05/more-mods.html
Thats quality ^^^
My brake arms are quite loose on the frame.... and its a fly frame!!!
You'd think they're own brakes would fit!
Re: Fly brakes
« Reply #9 on: June 03, 2008, 09:09 PM »
I really like fly stuff, and I think they do a great job of pushing BMX design. But I do think they have problems making parts. It seems like most fly brakes are loose on the posts, hence the noise. Ive also heard things about some of their frames not being right. Shame really. I wonder how much they are in control of their manufacturing.
subversion
Re: Fly brakes
« Reply #10 on: June 03, 2008, 09:11 PM »
I've just set up a Suelo front & the fork posts are a little long so it has some play in it. Going to get a file on the mofo at the weekend >:D
Voodoocars
Re: Fly brakes
« Reply #11 on: June 03, 2008, 09:26 PM »
I've had squeaky a brake for ages.I tried that ptfe tape thing- no good.I've even shimmed the brake posts on the frame so that there is no play at all- still no good.Toed in the pads- still no good. Full face helmet- result ! Cant hear the squeal any more!
Re: Fly brakes
« Reply #12 on: June 04, 2008, 07:52 AM »
or what you could do is spend a fraction of the cost and get a Hombre which just simply work??   ;)
subversion
Re: Fly brakes
« Reply #13 on: June 04, 2008, 03:03 PM »
In my experience Hombre's aren't HALF as good as a Fly brake :) (got a pair for sale cheap if anybody wants them?) Like you Pickle, I couldn't seem to justify the outlay initially but use them for a while & I doubt you'd go back...?
Voodoocars I take it you are running Fly's? If so are they CS or SS mounted? The brake is reacting diiferently depending on the frame position it's being used on... :daumenhoch:
I know Ray900tap uses a fly on CS without toe in & his brake is noisy as shit but he likes the 'bite' you get when running them that way...
Each to his/hers eh....
Re: Fly brakes
« Reply #14 on: June 04, 2008, 03:05 PM »
that's fair do's mate, i've never ran one so i guess i only know Hombre's or EvoII's
Voodoocars
Re: Fly brakes
« Reply #15 on: June 04, 2008, 05:10 PM »
No- I've got an Hombre on.I did think about getting a fly but cant be bothered.The problem with mine are the pads.They are ACOR clear pads on black rims and work really well.I've tried others  that dont squeal but just dont work very well.
Bettyswallocks
Re: Fly brakes
« Reply #16 on: June 04, 2008, 10:14 PM »
Just been interact at burnley, after adjusting the pads last night... fine no squeal anymore but the brake aint as good...  :(
Think i'll put em back as they were, instant wheel lock with one finger... noisy as feck though...  :daumenhoch:
Re: Fly brakes
« Reply #17 on: June 04, 2008, 10:20 PM »
try toeing them in a little less. Its probably cos their aint much block face hitting the rim now.
Re: Fly brakes
« Reply #18 on: June 05, 2008, 08:01 AM »
and also give em a rub with some sand paper in case they have developed a shene on the them  :daumenhoch:
