Pro Class Rim Tape Alternatives? Is there any?
<< < (3/3)
bobafett:
All different coloured foil ribbon here :
http://shop.ebay.co.uk/ed1835/m.html?_nkw=foil+ribbon+19mm&_sacat=0&_trksid=p3911.m270.l1313&_odkw=&_osacat=0
moley:
Cheers lads!!
I'll work out what I need and formulate a plan of action!!!  :D
Peter J:
http://cgi.ebay.co.uk/Thin-steel-strip-0-004-x-10-metres-Shim-Polished_W0QQitemZ290361199970QQcmdZViewItemQQptZUK_BOI_Metalworking_Milling_Welding_Metalworking_Supplies_ET?hash=item439ae04d62
 Its shim steel so low carbon content  :-\
meticulous:
supose packing out the inside rim with 2lb of tape is defeating the object why they were drilled out in the first place....  :D
Rodgy1970:
This was on the bmxmuseum too ;)
http://bmxmuseum.com/forums/viewtopic.php?id=170516
Supplier here
http://www.uniquetrials.com/V3/Products/VIZ/viztape.html
Navigation
[0] Message Index
[*] Previous page
Go to full version
