976306 Posts in 138996 Topics by 6434 Members - Latest Member: Darbs July 16, 2026, 11:24 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Pro Class Rim Tape Alternatives? Is there any?
Author Topic: Pro Class Rim Tape Alternatives? Is there any?  (Read 5410 times)
moley
« on: October 29, 2009, 10:12 AM »
I'm after something with the same consistancy as a proper Pro Class Rim tape.
Something that looks the part and does the job.
Metallic tapes are quite thin and bulge out like the woman with the big bulgey eyes!!  :(
I'd want a few different colors!!
Any ideas?
Cheers  :daumenhoch:
Offline Jt
Re: Pro Class Rim Tape Alternatives? Is there any?
« Reply #1 on: October 29, 2009, 10:55 AM »
hmmm.
i went to the habidashiry section in john lewis and bought a thin roll of fabric...
got a nice metallic look to it and is quite thick.
on the DY ( any excuse)
« Reply #2 on: October 29, 2009, 11:08 AM »
Couldn't you use anything then cover that with a regular rim tape?
Offline Jt
« Reply #3 on: October 29, 2009, 11:45 AM »
thats what i did.
moley
« Reply #4 on: October 29, 2009, 01:30 PM »
I'm using some metallic tape with the cardboard backing still on...........plus some electrical insulation tape and a proper rubber rim strip.
The trouble is its still bulges out too much with 50-60 psi behind it and looked a little to flimsy.
I was wondering if anyone has found a better alternative.
Offline stevochb
« Reply #5 on: October 29, 2009, 01:45 PM »
Used black tape and used some masking tape as backing for these and it worked ok
Offline stevochb
« Reply #6 on: October 29, 2009, 01:48 PM »
used ribbon for these ones with masking tape.
Offline jimmyp
« Reply #7 on: October 29, 2009, 01:51 PM »
There's a guy on usa ebay that does em, think they are $25 a pop but are just like the real thing. Think he's over on bmx museum, d cristo or somthing his name is, check him out nice lad  :daumenhoch:
Type Mongoose Pro Class in USA E-BAY, should find em there  :daumenhoch:
Offline oldtired
  • Dirty Old Man
« Reply #8 on: October 29, 2009, 02:21 PM »
have used lats from an aluminum blind before its about 1/2 mm thick so bends round the rim well , cover with gaffa tape to keep it in place and protect the tube from getting nipped  , can be sprayed to the colour you want and cos its alli you don't get any bulge   :daumenhoch:  pm moley if you want some i got miles of the  stuff   :daumenhoch:
« Last Edit: October 29, 2009, 02:39 PM by oldtired »
safc1
« Reply #9 on: October 29, 2009, 02:27 PM »
i've used "mylar" silver on one side, white on other. held in place with a normal rim tape. got it off ebay  ;)
moley
« Reply #11 on: October 29, 2009, 04:00 PM »
Cheers lads!!
I'll work out what I need and formulate a plan of action!!!  :D
Offline Peter J
  • I have issues
« Reply #13 on: October 29, 2009, 06:08 PM »
supose packing out the inside rim with 2lb of tape is defeating the object why they were drilled out in the first place....  :D
Rodgy1970
