removing the large nut on a tuf neck
Glynnyboy:
I thought the tiger looking to the right are ok to unscrew but the tiger looking to the left with a neck and a chain are a different story. Can anyone elaborate on this?
MartyC:
--- Quote from: glynnyboy on November 10, 2009, 06:58 AM ---I thought the tiger looking to the right are ok to unscrew but the tiger looking to the left with a neck and a chain are a different story. Can anyone elaborate on this?
--- End quote ---
NFI but if it's held in with a bolt I would guess it will undo; you may need to give it some gbh or use a press (which I did) to get the shaft out but it should come out. When you put it back together put aome tape on the topcap around the bolt (not under, but around) to avoid marking up your shiney new anno :daumenhoch:.
QUADROPHENIA:
if your sendintg it to paul at customwhateverhiscompanynameisasicantremeber you dont need to remove the shaft, he will just tape it up
neiljonarcus:
i just polished a tuff neck stem for matt "swivel" and he wanted the nut painted satin black so i undone the nut , the stem is taped out for the nut/bolt . come to think of it i should have took piccy,s of the nut out :idiot2:
trasher:
cheers guys ,,thought about leaving the stem in know ,after finding out paul can do it with it still in
having right trouble getting the nut out ,,,,,, need to get a vice me thinks :buck2:
Navigation
[0] Message Index
[*] Previous page
Go to full version
