976341 Posts in 138998 Topics by 6442 Members - Latest Member: Onlystans August 15, 2026, 09:27 AM
RADBMX.CO.UK  |  BMX General  |  BMX Chat  |  play in bottom of headset.
Author Topic: play in bottom of headset.  (Read 1499 times)
keviboy
« on: July 03, 2012, 08:45 PM »
<a href="http://s1072.photobucket.com/albums/w368/keviboy/Facebook/RACING%20RIPPER%20NEW%20BUILD%202012/?action=view&amp;current=IMAG0297.jpg" target="_blank"><img src="http://i1072.photobucket.com/albums/w368/keviboy/Facebook/RACING%20RIPPER%20NEW%20BUILD%202012/IMAG0297.jpg" border="0" alt="NEW SE LANDING GEAR FORKS IN CHROME THREADLESS 1 1/8THS">[/url]
hi i need some info!
I'm building a Team PK RIPPER  and the semi internal bearings went in fine,as did the new Landing gears fitted the spacer and stem and tightened everything up and there is play of about 2 mm's whats not right as i can't see whats wrong!!
Re: play in bottom of headset.
« Reply #1 on: July 03, 2012, 09:14 PM »
You need more spacers.......the stem should sit proud of the forks by about 5mm.  :daumenhoch:
Offline Devilock
« Reply #2 on: July 03, 2012, 11:33 PM »
should sit proud
Rob will come round & show you how it should sit proud...  :bondage:
keviboy
« Reply #3 on: July 04, 2012, 06:33 AM »
PLAY IN THE HEADSET ! NOT PLAY WITH IT!!! HE HAD BETTER COME EARLY AS IM UP AN OUT BY 4.30AM!!  :LolLolLolLol:http://
keviboy
« Reply #4 on: July 04, 2012, 06:30 PM »
Well this afternoon i striped  the front down and noticed the, i think its the bottom sleeve to the race needed knocking down a bit more so i did that engaged the forks back into the bottom bearing into the top bearing put the bearing collar cover back and added a 5mm spacer and 2mm spacer and my lully new robinson stem tightened the fangled nutty thing and the stem up and balls there is still about 1mm play in the headset! poxy thing!! what next?? should i take it to the bike shop and see what they say? they are Stanley bridge bikes in WALTHAM ABBEY the guy who manages the shop is into bmx bikes and love's rippers  and rides,
« Reply #5 on: July 04, 2012, 06:56 PM »
Put up a picture of the top of your stem without the top bolt in  :daumenhoch:
keviboy
« Reply #6 on: July 04, 2012, 07:11 PM »
i can do it at the crack a sparrow tomo as the bike is at work thanks for your time MR P!
keviboy
« Reply #7 on: July 05, 2012, 01:20 PM »
hope this photo bucket thing works!
http://s1072.photobucket.com/albums/w368/keviboy/?action-view&current=IMAG0013.jpg
the star fangled thingy!
« Last Edit: July 05, 2012, 02:49 PM by pickle »
Offline rooski
  • Mons Veneris
« Reply #8 on: July 05, 2012, 06:34 PM »
Knock the star nut down a few more mm,and put a spacer on the TOP of the stem,then the top nut and bolt back on :daumenhoch:
« Reply #9 on: July 05, 2012, 06:42 PM »
Are the bearings correct for it? That black spacer should sit flush to the race, it's got a great big gap  ???
keviboy
« Reply #10 on: July 05, 2012, 09:00 PM »
oki doki i will give it a go in the morning! and get back to you......i could be knocking on your door this weekend hahaha  have the spanners and sledge hammer on standby!
thank you
