976239 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 06, 2026, 04:15 PM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Tuf neck shaft stuck in Forks !!!!!!!!
Author Topic: Tuf neck shaft stuck in Forks !!!!!!!!  (Read 2081 times)
Offline Funkyworm
« on: March 14, 2013, 12:48 PM »
Ok so I have a new frame which came with a snapped tuf neck,
I managed to remove the head of the stem, stem bolt & headset but the shaft & wedge remain inside the forks .
Any ideas how to get these out ? I'm thinking turn the forks upside down spray with wd & hit the wedge upwards with a mallet & chisel ????????
Anyone with more civilised & proven sergical procedure is more than welcome to chip in   :daumenhoch:
« Last Edit: March 14, 2013, 01:04 PM by Funkyworm »
Offline mattbloke
Re: Tuf neck shaft stuck in Forks !!!!!!!!
« Reply #1 on: March 14, 2013, 01:08 PM »
as big a punch as you can that will fit down the centre of the fork, then know it out. if you screw the retaining bolt back into the quill piece to plug the hole you can then have the forks upside down and fill them with WD or a light penetrating oil   :daumenhoch:
Offline mattbloke
« Reply #2 on: March 14, 2013, 01:10 PM »
scrub that, just looed at the picture again DOH! fil the bottom of the fork with WD as i said, but you will need to knock the quill (the little bit on the end of the stem) down first so that it isnt keeping the shaft locked tight.
Offline Funkyworm
« Reply #3 on: March 14, 2013, 01:27 PM »
Sweet I screwed the quill bolt back in to the wedge gave it a tap downwards & it freed up the main shaft which i've removed with some of those plumbers clamps/ plier type things ALL SORTED
Now where to find a new stem for a Tuf Neck ????
Wanted section me thinks !
Offline Waxintaxin
« Reply #4 on: March 14, 2013, 01:47 PM »
what is snapped ? the alloy parts are pushed on to the steel shaft so nothing looks broken except the long bigger bolt and they are easy to get hold of
Offline Funkyworm
« Reply #5 on: March 14, 2013, 01:57 PM »
Yeah its the long (bigger bolt but it's broken inside of the shaft ) wouldnt have a clue how toget this out ?????
Offline Peter J
  • I have issues
« Reply #6 on: March 14, 2013, 02:06 PM »
Might be cheaper to send it to Steve and get him to sort it  :-\
Offline Waxintaxin
« Reply #7 on: March 14, 2013, 02:36 PM »
either weld a rod on the stuck thread and screw it out , or get one of those reverse drill bits that will screw it out , steve animal can do either i am sure or any engineering firm in your local area will easily get it out
then buy a new bolt and sorted
Offline Funkyworm
« Reply #8 on: March 14, 2013, 02:55 PM »
Cool I'll pm steve !
Cheers guys. (whilst we are on the subject (anyone got a bolt ?)
Offline senzo milano
« Reply #9 on: March 14, 2013, 03:36 PM »
I do have the bolt... for that  :daumenhoch:
I did had the same problem with the same stem,, i did split the forks.
But not a good idea if you want to save the forks...
Big bobbles ,no troubles
Offline Funkyworm
« Reply #10 on: March 14, 2013, 03:57 PM »
Patric you are a Legend !
PM me the price  :daumenhoch:
