976232 Posts in 138993 Topics by 6420 Members - Latest Member: churchclothes April 25, 2026, 09:43 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Reaction Megabrake
Author Topic: Reaction Megabrake  (Read 10787 times)
Reaction Megabrake
« on: August 04, 2015, 12:14 PM »
Anyone know what nuts the Megabrake conversion that Rob Ridge did take? or what TPI it is?
Its not the normal 'axle' thread so maybe Skyway type?
Cheers  :daumenhoch:
If you have a spare nut that you can send me thats EVEN BETTER  :daumenhoch:
Re: Reaction Megabrake
« Reply #1 on: August 04, 2015, 04:03 PM »
Ed - I don't think it was a bicycle thread at all but I do stand to be corrected.
Rob Ridge is a facebook buddy - shall I ask him for you?
Offline john4130
« Reply #2 on: August 04, 2015, 06:51 PM »
got a couple of reaction boa's here, one 10mm and the other 8mm. the 10mm uses a m10x1 nut. the original nuts are 3mm thick and there's 3 of them.
Offline chubby
  • Needs Pegs
« Reply #3 on: August 04, 2015, 10:59 PM »
No idea what one is, megabrake sounds super cool so someone show  me what it is  :slayer:
Offline john4130
« Reply #4 on: August 04, 2015, 11:27 PM »
it's a regular acs boa with the bearings replaced with sealed one's and a thicker axle.
Offline chubby
  • Needs Pegs
« Reply #5 on: August 05, 2015, 12:08 AM »
Ahhh !!!
Thought about that when I rebuilt mine the other month, didn't know it'd been done  :teef:
« Reply #6 on: August 05, 2015, 02:26 AM »
Not heard back from Ridger yet.
Taking John4130's info, I believe that pitch of 1mm makes it Metric Fine. A little more unusual but easily sourced from engineers supplies shops.
« Reply #7 on: August 05, 2015, 08:51 AM »
cheers fellas :-)
« Reply #8 on: August 05, 2015, 08:52 AM »
any chance of a pic of yours John :-)
Offline john4130
« Reply #9 on: August 05, 2015, 05:39 PM »
i'll post up a couple of pics tomorrow.
« Reply #10 on: August 05, 2015, 06:04 PM »
Cheers  :angel:
« Reply #11 on: August 05, 2015, 11:06 PM »
Update from the man himself;
3/8"x26tpi is the correct thing. You have a Facebook PM Ed :)
« Reply #12 on: August 06, 2015, 03:52 PM »
« Reply #13 on: August 06, 2015, 03:59 PM »
For god sake some one post a pic of this damn thing
« Reply #14 on: August 06, 2015, 04:56 PM »
 ;D  glad i'm not the only one thinking that
Offline john4130
« Reply #15 on: August 06, 2015, 07:27 PM »
this is my 10mm reaction boa, it's not complete as i lost a bearing and the spring, it uses four sealed bearings so when tightened, it gives almost zero flex but still very smooth. best caliper brake ever.
it does indeed have a 3/8 26 tpi axle as i just tried a wheelnut on it and it fitted.
this is my 8mm one, it still uses 10mm sealed bearings but the axle reduces from 10mm down to 8mm.
Offline chubby
  • Needs Pegs
« Reply #16 on: August 06, 2015, 08:31 PM »
To the cave with a vernier  :teef:
Offline Christhejob
« Reply #17 on: August 06, 2015, 08:42 PM »
Offline chubby
  • Needs Pegs
« Reply #18 on: August 06, 2015, 08:46 PM »
Any numbers on the bearings John ??? Boas measure at 18mm & Little bearings are 17 or 20mm
Offline john4130
« Reply #19 on: August 06, 2015, 09:02 PM »
there are no numbers on the bearings but i ordered a vernier caliper the other day, so when it turns up i'll get the sizes of them.  :daumenhoch:
Offline chubby
  • Needs Pegs
« Reply #20 on: August 06, 2015, 09:12 PM »
Bet they're old odd skateboard wheel bearings or something daft. They look a snug fit from your pics & the boa arms don't appear to be modified  :chin:
Offline fugazi
« Reply #21 on: August 07, 2015, 09:08 AM »
Yes pretty sure they had skateboard wheel bearings in them  :daumenhoch:
« Reply #22 on: August 07, 2015, 09:11 AM »
Nah... skateboard wheel bearings are LOADS bigger ... will take a pic if I can be fooked  ;D
Thanks for the pics tho John  :smitten:
Offline john4130
« Reply #23 on: August 11, 2015, 07:05 PM »
just measured the bearings used in the brake. o.d is 18.97mm, i.d is 9.99mm and width is 5mm incase anyone wants to have a go at making one.  :daumenhoch:
« Reply #24 on: August 11, 2015, 07:36 PM »
Easily found at those dimensions  :daumenhoch:
