976294 Posts in 138996 Topics by 6431 Members - Latest Member: lemus June 17, 2026, 03:01 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  Powder coat v Starchems
Author Topic: Powder coat v Starchems  (Read 3989 times)
Offline kalex
« on: September 17, 2018, 05:26 PM »
I'm fairly sure starchems can and has been used to good effect on removing powder coating but before I slap it all over I would like some confirmation please
Offline Nigel
Re: Powder coat v Starchems
« Reply #1 on: September 17, 2018, 06:09 PM »
Its as good as nitromorse but I would give it a good scrape with a Stanley blade first
I use Bartoline TX10  just as good an cheaper
Offline chubby
  • Needs Pegs
« Reply #2 on: September 18, 2018, 08:08 AM »
Sbd uses starchem
Sent from my G8341 using Tapatalk
Offline Cherrypicker
« Reply #3 on: September 18, 2018, 09:46 AM »
I’ve used nitromors on the RL20 I’m doing with only partial success after several treatments. Found some organic environmentally safe stuff which took a little more off. Then I went for TX10 which has removed most but not all the paint, again after several treatments. Anybody used the Aircraft Remover? Watched demos of it online, appears to just rip it off in minutes?? Struggling to get paint from the welds.
HIT ME UP IF YOU GOT A TEAM PRODUCTS LEVER (RIGHT) TO SELL
Offline chubby
  • Needs Pegs
« Reply #4 on: September 18, 2018, 10:18 AM »
I use a brass wire brush in the awkward areas, doesn't scratch the metal..
Offline Taipan
« Reply #5 on: September 18, 2018, 12:18 PM »
So is there actually a brand that will work without any hassle like we used to use bitd  without any probs??  before they took all the ingredients that made them work!
Offline CustardLips
« Reply #6 on: September 18, 2018, 12:41 PM »
Starchem is the brand Carl... Synstrip is the product.  :daumenhoch:
"WWG1WGA"
Offline kalex
« Reply #7 on: September 18, 2018, 01:31 PM »
I only use starchems and would never bother with nitromors, but I've only used it on paint and have heard it can be done with powder.
I've got forks and bars which have been powdered albeit at a average standard but before I go and slap starchems all over it I wanted to know if it'll do the job. Its only on a everyday rider and I can put up with the powder job but as I've got starchems sitting around I thought I'd have a go.
« Reply #8 on: September 18, 2018, 02:15 PM »
Starchem synstrip ordered. Hopefully that will get the last of it off 👍
Offline Funkyworm
« Reply #9 on: September 23, 2018, 06:39 PM »
Should do mate I've used it on powder loads.
Put it on & then place the frame in a bin bag or one of those bags you get with oven pride . it'll help keep the synstrip wet so it works better for longer .
You don't want it to dry out otherwise you'll have to apply more ...  :daumenhoch: Also do it in a ventilated room as you dont want to be breathing too much of that stuff in ...
