976238 Posts in 138993 Topics by 6422 Members - Latest Member: ludwig242 May 05, 2026, 07:59 AM
RADBMX.CO.UK  |  Technical & Reference Section  |  Tech and Restoration  |  PK Ripper........ Do i or Dont i ?
Author Topic: PK Ripper........ Do i or Dont i ?  (Read 4137 times)
FuNMoNsTeR
« on: March 20, 2007, 12:10 PM »
As you probably know i have a Black Loopy ripper with original finish... Do i strip it and repowder or leave it? Do i just strip the top of the rear tri where the marks are and touch it up to try and keep as much of the original finish as possible?
   I also have a graphite Uni seat to remove.... I was going to saw it off about an inch above the seat tube and then give the remaining protuding piece a sharp whack straight downward with a soft Thor hammer... Do you reckon this will free it?  Any help or advice appreciated as always :)
Frameset
SeatPost
Rear Tri Marks
Re: PK Ripper........ Do i or Dont i ?
« Reply #1 on: March 20, 2007, 12:14 PM »
i would leave it as is.
cut the post     and run an undersized drill down it until its nearly throu   then hacksaw blade inside.
Frosty
« Reply #2 on: March 20, 2007, 12:20 PM »
the frame looks pretty good, leave the patina!!
Offline kdw712
« Reply #3 on: March 20, 2007, 12:21 PM »
i'd leave it too - survivors are the best
build up with other parts that have the same kinda aged look to them
with the seat try everything before cutting it (not sure if you have already)
cheers Kev
Offline ORB
« Reply #4 on: March 20, 2007, 12:30 PM »
I like taking stuck posts out, and it can be a bitch.
that is graphite me thinks, thus should be fairly easy, try a bit of petrol in there, that may help, then twisting in a vice, if that fails, try drilling it with care, then, a hack saw blade.
Some of them can be a bitch, but i think this one will let go.
12
FuNMoNsTeR
« Reply #5 on: March 20, 2007, 01:07 PM »
Thanks guys :)
  I didnt really want to do any sort of twisting as ripper seat tubes dont respond well to that sort of stress... I will soak the post first and give a go though :)  If that doesnt work i will try Dannys method  ;)
Offline brass monkey!
« Reply #6 on: March 20, 2007, 01:10 PM »
..... try a bit of petrol in there, that may help,
.....and don't forget to extinguish any smoking materials beforehand matey !!  ;) ;)
« Reply #7 on: March 20, 2007, 03:31 PM »
Is it worth re powdering it and spending all that money on if you're going to ride it??  you know it'll only last a week or two before it snaps  ;)
Leave as is......i like the survivor ones  :daumenhoch:
« Reply #8 on: March 20, 2007, 04:18 PM »
I remember having to get a uni post out of a frame as a kid and not having much trouble banging it out with with a screw driver and a hammer ::)
Offline jT Racing
  • i like bikes. :/
« Reply #9 on: March 20, 2007, 06:19 PM »
get a hairdryer, heat the seattube, twist out seatpost. :daumenhoch:
ding dong
Offline jT Racing
  • i like bikes. :/
« Reply #10 on: March 20, 2007, 06:20 PM »
oh, and a tiny(and i mean tiny) bit of proper thinners will go between tube and post and work as a lubricant, be sure to rinse off straight away!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ding dong
Offline region11
« Reply #11 on: March 20, 2007, 06:23 PM »
As its in such a good original condition, id leave it  :)
Neil
« Reply #12 on: March 20, 2007, 07:52 PM »
strip it and refinish it. it's only paint. may as well make it look as minty as it deserves to.
scary_leary
« Reply #13 on: March 20, 2007, 07:53 PM »
Could you not just drill a hole near the top of the post.
then push a long metal rod through... wide grip, turn and pull
gavking
« Reply #14 on: March 20, 2007, 08:03 PM »
Yeah the way I would do it is as scary leary says"""
I normaly empty a can of wd40 down it leave it over night then drill a hole through the top of the post. probs about 8mm if ya can then I put an allen key through that hook it with the end of a long ring spanner and turn. Heat the frame up if you can but not hot just warm.
Then when it turns I put a seat on and twist in the normal way to get it out.
Just done it on a jammed post in my profile frame and it worked straight away.
Jazzchimp
« Reply #15 on: March 20, 2007, 08:06 PM »
The posts react with the alloy of the ripper, they're notorious for it.
my advice is grease your pole well!!
Jazzchimp
« Reply #16 on: March 20, 2007, 08:07 PM »
Oh and how about bolting a stem on to the post, then giving it some with a large lever??!!
digitaltransfer
« Reply #17 on: March 20, 2007, 09:36 PM »
Frameset
SeatPost
Rear Tri Markser
someone I knew used to ride for SE BITD Sam a lady now cant remember her surname but she had the exact same frame and orig set up I will find out and get some pics she used to live round the corner form me
FuNMoNsTeR
« Reply #18 on: March 21, 2007, 01:24 PM »
Good idea with the stem Jazzchimp... I have already sawn the post off though  :D
The seat post is out now :)   Zero damage  :D
Thanks all...i will post a pic in a few minutes  :)
FuNMoNsTeR
« Reply #19 on: March 21, 2007, 03:09 PM »
The Piccys of the seat tube... and remnants of the naughty seatpost in question  :D
Offline jT Racing
  • i like bikes. :/
« Reply #20 on: March 21, 2007, 05:36 PM »
now get it stripped and coated :daumenhoch: in your frontroom with a porn vid playing :daumenhoch:
ding dong
